SMath Studio Forum
Samples
Double Integration using ode solvers
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions. DoubleIntegralRK.sm (43kb) downloaded 73 time(s). DoubleIntegralRK.pdf (220kb) downloaded 83 time(s).Best regards. Alvaro.
on 04/06/2020(UTC), on 04/06/2020(UTC)
Joined: 02/05/2020(UTC) Posts: 41 Was thanked: 3 time(s) in 3 post(s)
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition? |
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman) |
Originally Posted by: SteelCat Can the change of variable be put in the procedure definition,? Like this: yes, just opposite plot. Double Switch [x, L].sm (7kb) downloaded 32 time(s).
on 18/06/2020(UTC), on 18/06/2020(UTC)
Originally Posted by: Jean Giraud Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath. In the attached Laguerre and Legendre coeffs for the Gauss method. DoubleIntegralJean.sm (26kb) downloaded 41 time(s). DoubleIntegralJean.pdf (46kb) downloaded 38 time(s).Best regards. Alvaro
on 19/06/2020(UTC), on 19/06/2020(UTC)
Originally Posted by: Razonar Hi Jean. Yes, can copy and paste. Thanks, Amigo !
SMath Studio Forum
Samples
