Offline nmoregon
#1 Posted : 08 March 2019 21:21:34(UTC)
nmoregon
Hi just upgraded to 0.99 build 7005 and something significant has changed. In all previous versions, when I opened a file by double-clicking on the file name, then opened a second file the same way, the second file would open up in its own window. I could arrange them side by side. Now, the second file is automatically added as a new page instead of having its own window. How do I get back to the previous behavior? I use this a LOT.
Thanks!
Nora
Contractor - Knovel
Offline nmoregon
#2 Posted : 08 March 2019 21:29:08(UTC)
nmoregon
I see now that the files can be viewed side by side within the SMath window, instead of as separate windows. That's good, but frankly I still prefer the previous behavior. I was able to switch between files, or relocate one by looking at the Windows menu bar. I presume this was done to better manage resources. Is there any chance the older behavior could be retained as well?
#3 Posted : 08 March 2019 22:42:32(UTC)
It is by design, to improve performances on average usage:
Originally Posted by: Andrey Ivashov Go to Quoted Post
Single instance of application is used for all files to open from shell now;
You can change it though, as written in the announcement:
Added possibility to disable single application instance feature (add line SingleInstance=0 into settings.inf file);
on 08/03/2019(UTC)
Offline nmoregon
#4 Posted : 08 March 2019 23:03:26(UTC)
nmoregon
Thank you Davide! I did not see that mention. You'll note I am a "newbie" (although have used it for a few years, not very much). Where do I find the settings.inf file on a Windows system? I searched for it in the Smath Studio folder and found none.
#5 Posted : 08 March 2019 23:13:02(UTC)
Welcome in the forum Good
The settings file is in %APPDATA%\SMath (you can paste it in the address bar of any window or type it in the start menu)
Edited by user 08 March 2019 23:14:55(UTC)  | Reason: Not specified
on 08/03/2019(UTC)
Offline nmoregon
#6 Posted : 09 March 2019 00:40:51(UTC)
nmoregon
I should have known that but, well, I didn't. All fixed.
Thanks so much!
Edited by moderator 09 March 2019 14:53:50(UTC)  | Reason: marked as Solved
Guest (2)
