Offline Andrey Ivashov
#1 Posted : 07 March 2019 21:32:16(UTC)
Was thanked: 1977 time(s) in 665 post(s)
SMath Studio - SMath
Created by Andrey Ivashov in the scope of SMath project. Published by smath.
SMath Studio box
Version 1.0.8348 - Stable (released at )
Downloads: 1778591 Download
Open in browser
Changes history
Must have for every engineer. more...
by Florian
Excellent program. Thanks to his author for freely sharing such an amazing piece of software. Thumbs up. more...
by A Chang
Absolutely Gorgeous software, which can be a level riser for spreadsheet calculation, seamlessly extended for any kind of mathematical application. more...
by Shiju VT
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
thanks 10 users thanked Andrey Ivashov for this useful post.
on 07/03/2019(UTC),  on 07/03/2019(UTC),  on 07/03/2019(UTC),  on 08/03/2019(UTC),  on 08/03/2019(UTC),  on 08/03/2019(UTC),  on 08/03/2019(UTC),  on 08/03/2019(UTC),  on 10/03/2019(UTC),  on 30/03/2019(UTC)
Offline RegCurry
#2 Posted : 08 March 2019 00:40:44(UTC)
RegCurry
I appreciate all your hard work on this software; however, please turn off the popup trying to install the 7005 version every time I open my 6884 version. There are too many plugins that I need that no longer work with the 7005 version.
Thanks again for all your hard work.
Reg curry
#3 Posted : 08 March 2019 02:20:42(UTC)
Was thanked: 1322 time(s) in 872 post(s)
Go to: Tools > Plugins... > SMath Studio
then enable the option "Don't check for updates"
Offline RegCurry
#4 Posted : 08 March 2019 06:35:13(UTC)
RegCurry
I did. However, now I cannot even use the older version with maple or XY plots. This has totally ruined my workflow. Let me know when this is fixed and I will return to Smath.
Censored :'( Mad
Offline RegCurry
#5 Posted : 08 March 2019 06:44:30(UTC)
RegCurry
Also, there is not Tools>Plugins>SMath Studio
There is only Tools>Plugins>Online gallery
Sad
Offline RegCurry
#6 Posted : 08 March 2019 08:27:50(UTC)
RegCurry
Thanks for adding in the maple and XY plot plugins.Clap
Offline mkraska
#7 Posted : 08 March 2019 10:13:27(UTC)
mkraska
Was thanked: 1103 time(s) in 704 post(s)
Censored :'( Mad
I generally recommend to not upgrade the installed version until you verified that new versions are functional to the level you need.
To test new versions, use the linux version (yes, it runs under Windows and yes it is significantly smaller), unpack it to some directory and add a file named portable.version to that directory. Then you have a sandbox which is totally independent of the "installed" SMath version.
#8 Posted : 08 March 2019 11:41:09(UTC)
Sad
Is the first item in the left panel
Once you reinstalled the old program version go in the Extensions Manager (Tools > Plugins) and remove the plugins you have previously updated in the newer version (select each plugin that has a red backkground or didn't work as expected, then click on the trash bin), finally switch the top right button from "Local Storage" to "Online Gallery" and reinstall the extensions you need.
Edited by user 08 March 2019 11:45:19(UTC)  | Reason: Not specified
Offline andrbig77
#9 Posted : 08 March 2019 14:59:36(UTC)
andrbig77
Добрый день, уважаемые эксперты SMath.
Спасибо за вашу работу и за новое обновление SMath Studio.
Я обратил внимание на следующую особенность в новоей стабильной версии Smath 0.9.0075.xxx, когда пользователь удаляет строки в документе с помощью клавиши 'Delete‘.
Так не виден маркер удалемых строк и вообще строка статична. Она не двигается вверх, пока жмешь кнопку 'Delete‘. И только потом после операции удаления нескольких строк весь документ сдвигается вверх. А во сколько строк удаляется в процессе удержания кнопки 'Delete‘ - неизвестно . Если риск удалить и сам фрагмент текста или формулы, если маркер находится над ними и пользователь удерживает кнопку 'Delete‘.
С уважением Андрей
p.s. могу выложить видео, но не знаю как на форуме это видео выложить
Offline sinneD
#10 Posted : 15 March 2019 00:38:52(UTC)
sinneD
Was thanked: 16 time(s) in 7 post(s)
Martin- Thank you for this!
How do you recommend to handle the different plugin versions? If there is a version update to the plugin, is it safe to assume that the updated plugins are 100% backward compatible?
Thanks
Dennis
Offline mkraska
#11 Posted : 15 March 2019 11:42:22(UTC)
mkraska
Thanks
Dennis
If you are working with different portable versions, then you have separate directories for each of them. Each version has it's own extensions subdirectory, which you need to fill using the extension manager. Then the extension manager should offer you the plugin versions appropriate for the particular SMath version. Usually this works reliably. Never just copy the extension subdir from some other portable version.
Offline mkraska
#12 Posted : 17 March 2019 18:14:22(UTC)
mkraska
German handbook updated.
Available via Extension manager or website.
on 17/03/2019(UTC),  on 17/03/2019(UTC)
Offline mkraska
#13 Posted : 20 March 2019 16:35:58(UTC)
mkraska
Andrey, did you deliberately change shortcuts for greek letters?
f Ctrl-G now produces the closed phi sign (\phi in LateX). In previous versions it used to produce the open version of the sign (\varphi)
I'd vote for the old version.
on 20/03/2019(UTC),  on 22/03/2019(UTC)
Offline sinneD
#14 Posted : 21 March 2019 03:56:43(UTC)
sinneD
they got flipped-flopped- i did not notice until you pointed it out.
i remembered the mention that it was added the 2 'special' greek chars, but I could not figure what it meant until i looked at the symbols panel. if you hover over the symbol, it gives you the shortcut in the new version.
curiously, in 6839, the hotkey work, i do not remember when they got added.
thanks 2 users thanked sinneD for this useful post.
on 21/03/2019(UTC),  on 22/03/2019(UTC)
#15 Posted : 22 March 2019 09:54:24(UTC)
Looks like a bug. Will fix it. Thank you!
