Offline Razonar
#1 Posted : 28 February 2019 02:41:15(UTC)
Razonar
Uruguay
Hi. Is this the expected behavior?
Append.sm (7kb) downloaded 16 time(s).
I hope not. I expect A' = [1 2 3 4]
#2 Posted : 28 February 2019 03:32:07(UTC)
Alvaro: maybe like this ?
Offline Razonar
#3 Posted : 28 February 2019 03:53:45(UTC)
Razonar
Uruguay
Hi Jean. Nope, maybe more like this:
BTW, this is a workaround. I expect this result but for the previous syntax.
#4 Posted : 28 February 2019 04:20:41(UTC)
You just append, my code inserts wherever needed.
My mistake I named Append(,,,)
OK, you are imitating MCD.
Simpler Append: transpose the row, stack, re-transpose.
Offline Razonar
#5 Posted : 28 February 2019 04:25:09(UTC)
Razonar
Uruguay
I'm trying to imitate Wolfram's Mathematica Append.
#6 Posted : 28 February 2019 07:59:51(UTC)
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (16kb) downloaded 15 time(s).
#7 Posted : 28 February 2019 11:48:34(UTC)
Was thanked: 1334 time(s) in 877 post(s)
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
Edited by user 28 February 2019 12:43:45(UTC)  | Reason: Not specified
thanks 3 users thanked Davide Carpi for this useful post.
on 28/02/2019(UTC),  on 28/02/2019(UTC),  on 28/02/2019(UTC)
#8 Posted : 28 February 2019 19:22:34(UTC)
#9 Posted : 28 February 2019 20:42:13(UTC)
... append this Jacobian matrix.
Offline Razonar
#10 Posted : 28 February 2019 21:05:51(UTC)
Razonar
Uruguay
Close. Correct it's Saludos Jean.
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
Edited by moderator 01 March 2019 21:09:41(UTC)  | Reason: marked as Solved
#11 Posted : 01 March 2019 07:03:18(UTC)
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
