Hi. Is this the expected behavior? Append.sm (7kb) downloaded 16 time(s).I hope not. I expect A' = [1 2 3 4] Best regards. Alvaro.
Alvaro: maybe like this ?
Hi Jean. Nope, maybe more like this: BTW, this is a workaround. I expect this result but for the previous syntax. Best regards. Alvaro.
Originally Posted by: Razonar Hi Jean. Nope, maybe more like this: You just append, my code inserts wherever needed. My mistake I named Append(,,,) OK, you are imitating MCD. Simpler Append: transpose the row, stack, re-transpose.
Originally Posted by: Jean Giraud ... OK, you are imitating MCD. ...
I'm trying to imitate Wolfram's Mathematica Append.
Originally Posted by: Razonar I'm trying to imitate Wolfram's Mathematica Append. Not that much miraculous Mathematica 4.0 Mathcad APENDPRN was almost never used. Useful to compact/file a data set with wisely collected the fitting coefficients. On that application, Smath is far superior ... Explain Smath can save same stuff + the formula ... WOW ! Saludad Alvaro [is that correct ?] Page24 Alvaro.sm (16kb) downloaded 15 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1335 time(s) in 878 post(s)
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix: The new indices are added expanding the matrix vertically; there is no special case for single-row matrices. For your task, one way could be this: Or this: Edited by user 28 February 2019 12:43:45(UTC)
3 users thanked Davide Carpi for this useful post.
on 28/02/2019(UTC), on 28/02/2019(UTC), on 28/02/2019(UTC)
... append this Jacobian matrix.
Originally Posted by: Jean Giraud Saludad Alvaro [is that correct ?]
Close. Correct it's Saludos Jean. Originally Posted by: Davide Carpi Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results: Best regards. Alvaro. Edited by moderator 01 March 2019 21:09:41(UTC)
| Reason: marked as Solved
Originally Posted by: Razonar Just as comment, matlab don't follow that, and gives this results: What Matlab does Smath does as well with lot more user specifics. Matlab => MDA [Muliti Dimensional Array] Mathematica => Cell Array They just have their system. I can do whatever from this example and very quick too, just few more modules. MDA_1.bmp (1,076kb) downloaded 15 time(s).
