7 Pages«<23456>»
#61 Posted : 13 April 2016 20:13:36(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- SS-2315: cases() doesn't allow creating third row;
- cases(3) used by default instead of cases(1);
#62 Posted : 19 April 2016 02:50:27(UTC)
PLUGIN UPDATED SMath Studio 0.98.5952 Nightly Build only
Please note: if you have it, update of Custom Glyphs plugin is mandatory to make everything working fine (hidden functions removed, no more interactions between these plugins since this SS version)
- now it is possible to delete placeholders;
- adding placeholders now is "one-by-one" -> will be displayed a non-working cases() when you add or delete a placeholder;
on 19/04/2016(UTC)
Offline Alex M.
#63 Posted : 16 May 2016 23:17:54(UTC)
Alex M.
Davide, could you plese update the cases() function to work with units on the RHS? Hugely usefull when integrating piecewise physical properties.
Thank you!
Edited by user 16 May 2016 23:26:46(UTC)  | Reason: Not specified
#64 Posted : 17 May 2016 01:24:51(UTC)
Alex, the 1st condition in your cases() is wrong in both the functions.
You are using 1*'m≤x≤5*'m that bracketed it is (1*'m≤x)≤5*'m; this obviously fails because when you insert 2'm, the result is (1)≤5*'m, hence the "units don't match" error; note that in the 2nd case the error is silent (you will have always 0≤5 or 1≤5).
If you want to have the ternary operator for readability, use lele(...) from the same plugin, that does the job in the right way for you (lele(B,A,C)=(A≤B)&(B≤C)).
Edited by user 17 May 2016 01:57:32(UTC)  | Reason: Not specified
#65 Posted : 17 May 2016 01:50:12(UTC)
PLUGIN UPDATED SMath Studio 0.98.5973 Nightly Build onlyBeta
- added image2rgb() / image2rgba();
Offline mkraska
#66 Posted : 28 May 2016 18:38:55(UTC)
mkraska
The function at() seems to have a problem similar to those observed in the maxima plugin.
atproblem.PNG atproblem.sm (5kb) downloaded 60 time(s).
on 28/05/2016(UTC)
#67 Posted : 28 May 2016 19:22:02(UTC)
I prefer the compactum style.
Offline Razonar
#68 Posted : 30 May 2016 03:31:12(UTC)
Razonar
Uruguay
Hi. I guess that args for cases must to be unevaluated, like those if statements above. That's not only for errors, also for improve the speed of cases, which seems to eval all options before give the answer.
Offline mikekaganski
#69 Posted : 30 May 2016 04:25:49(UTC)
mikekaganski
Was thanked: 151 time(s) in 107 post(s)
I suppose you may want to vote for SS-2316.
Best regards,
Mike Kaganski
#70 Posted : 30 May 2016 06:12:47(UTC)
I can't comment wrt your actual version. "cases" does not come with OFFicial 5346,
but is available with the UNofficial 5346. The gorgeous application [made work by
Davide] is the convolution. I tried "cases" in other work sheets and failed.
I toke the plunge to install 5935 ... that killed most of 5346 work sheets.
More nightly build, more incompatibility and less projects working.
Not enough collabs publish working projects.
#71 Posted : 30 May 2016 06:29:02(UTC)
... there is more to test: as is, 5346 X_Y plot does not support "if/else".
What about plotting some discontinuous from your prefered nightly build ?
Offline Razonar
#72 Posted : 30 May 2016 06:47:19(UTC)
Razonar
Uruguay
I see: Yep.
#73 Posted : 30 May 2016 11:01:52(UTC)
Thank you Martin, I'll work on it ASAP.
As mentioned by Mike, this is addressed under SS-2316. As for now to evaluate only the function for the target condition you have to use eval() inside functions or numerical optimization outside functions.
I can't reproduce the first error shown in your picture, what plugin version are you running and in what SMath Studio?
Edited by user 30 May 2016 11:03:56(UTC)  | Reason: Not specified
Offline Razonar
#74 Posted : 31 May 2016 01:05:53(UTC)
Razonar
Uruguay
Hi Davide. In the attached, with background are all errors "division by zero" cases_error.sm (99kb) downloaded 64 time(s).in version 0.98 b5935 (last stable build, as I understand). Plugin version 1.1.5947.155599
#75 Posted : 31 May 2016 10:51:10(UTC)
Thank you, I can reproduce. This is before the SS-2318 implementation. In this case, you have to switch the optimization to numeric (symbolic uses the boolean sum and SMath ignores that x is a function's argument). If the function is behind a line, you have to wrap it in a eval().
Edited by user 31 May 2016 11:34:38(UTC)  | Reason: Not specified
on 01/06/2016(UTC)
#76 Posted : 08 June 2016 10:32:11(UTC)
PLUGIN UPDATED SMath Studio 0.98.5990 Nightly Build only
- fixed at(2) at(3);
- Unknowns now skips the "iterator" argument of diff/int/sum/product functions;
Edited by user 08 June 2016 10:35:36(UTC)  | Reason: Not specified
on 08/06/2016(UTC),  on 08/06/2016(UTC)
Offline bdrunagle
#77 Posted : 09 June 2016 23:03:07(UTC)
bdrunagle
Rank: Member
United Kingdom
Was thanked: 13 time(s) in 6 post(s)
Hello Davide
Sorry to be thick but I need some help with the cases function.
When I type case( or enter cases from the Insert Function… menu, only two lines are placed on the worksheet:
http://smath.info/wiki/G...2fcases_if_otherwise.png
and I don't know how to add extra if cases.
I've tried dragging corners, as for adding array rows, but with no success. How can I add more cases?
Smath: 0.98.5997
Custom Functions: 1.1.5981.13453
Custom Glyphs: 1.1.5973.13108
Many thanks
Brian
Offline Razonar
#78 Posted : 09 June 2016 23:10:24(UTC)
Razonar
Uruguay
Hi bdrunagle. Try to write , (or ; if you have this as separator) inside the placeholder of cases. This give you the new extra lines. But be carefull, after inserted, can't be deleted. (Must to copy and paste to new one cases).
#79 Posted : 09 June 2016 23:30:39(UTC)
Correct Good
Since some nightly build it is possible (the cost is that you cannot insert a line at once, you have to press the argument separator twice)
Offline Razonar
#80 Posted : 09 June 2016 23:38:25(UTC)
Razonar
Uruguay
That's seems a very cheap price.
Guest (18)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages«<23456>»
