3 Pages<123>
#21 Posted : 29 February 2016 21:56:11(UTC)
Was thanked: 1323 time(s) in 873 post(s)
Originally Posted by: ioan92 Go to Quoted Post
I beg you pardon, but I tried on two machines; I updated your last issue, but no result like in you image.
The cursor moves, but no label.
Maybe it is a problem of MS libraries.
Odd behavior... Wallbash
Not sure if is something in the .NET libraries or about the video card libraries...
on 29/02/2016(UTC)
#22 Posted : 01 March 2016 19:53:41(UTC)
Hello Ioan,
I've seen that the "Slider" label is "blinking" with a certain frequency.
I wonder if it would not be better to keep the label permanently visible ?, of course if possible.
I can keep it visible only when the region is focused, indeed seems better for the usage.
I observed that in an old file, the slider label is not visible, even when I introduce a new slider.
I recognize, they are very complicated the "informatics" ("God" ) paths...
Buggy, I'll fix it.
Edited by user 01 March 2016 20:09:45(UTC)  | Reason: Not specified
on 01/03/2016(UTC)
#23 Posted : 01 March 2016 20:26:08(UTC)
Try now, I've changed the repaint logic of the label.
edit: found an error in the coordinates, working to another update...
Edited by user 01 March 2016 20:34:17(UTC)  | Reason: Not specified
on 01/03/2016(UTC)
#24 Posted : 01 March 2016 21:15:46(UTC)
UPDATED
- Fixed coordinate system used to paint the label;
- Updated value after form closing; (<--- I see there was at least a download in a "nightly build", please update again)
PS: From my viewpoint, the problem is closed now.
Thank you for pointing out the bugs Good
When I have enough time I'll try to add the permanent labels to the ticks Wink
Edited by user 01 March 2016 21:20:09(UTC)  | Reason: Not specified
on 01/03/2016(UTC)
#25 Posted : 01 March 2016 22:16:04(UTC)
PLUGIN UPDATED
- fixed restoring of custom size on loading saved worksheet;
Edited by user 01 March 2016 22:46:21(UTC)  | Reason: Not specified
on 01/03/2016(UTC)
#26 Posted : 01 March 2016 23:09:36(UTC)
What else the people can dream ?
A smart cat giving the step by step to install in 5346.
I mean from:
1. psuh the button to start PC,
2. start the coffe pot,
3. then,
4. then
... and so on.
Thanks, it will be useful in many instances
particularly when seeking to initialise "Genfit" parameters.
on 02/03/2016(UTC)
Offline Alex M.
#27 Posted : 03 March 2016 20:22:36(UTC)
Alex M.
Hi Davide,
Thank you very much for the plugin, looks like I will be using it quite a bit more now Biggrin Good
Any chance you could incorporate setting the range of the slider? Right click -> menu button "Slider Range" will do.
I am working on creating graphically live strut & tie model and it would be of much help to see the actual values when you move the sliders.
Thanks again,
AM
P.S.: You need to download both files attached to see my example
st.xlsx (18kb) downloaded 131 time(s). st.sm (100kb) downloaded 223 time(s).
Edited by user 03 March 2016 20:29:52(UTC)  | Reason: Not specified
#28 Posted : 03 March 2016 20:50:36(UTC)
Alex, doubleclick on the region and you can set maximum/minimum/increment values (integers); you can setup these value by variables on the canvas (see attchment on post #1)
on 03/03/2016(UTC)
Offline Alex M.
#29 Posted : 03 March 2016 21:28:18(UTC)
Alex M.
Hi Alex, Good
I tried your files.
It works fine.
I profit to learn a little bit more.
I'm not sure to penetrate alone, your logic.
Please, if you may, make me a little bit of pedagogy.
Who is doing what and why?
Maybe, if I understand well your strategy, I could adopt it "for my government".
I understood you want to analyze a concrete beam by the method of struts ans ties.
Why do you need both - SMath and Excel ? IMHO, such calculations can be done as well in Excel as in SMath. Also the drawings (?).
Thank you and please apologize if this bothers you.
Best Regards,
Ioan
Hi Ioan,
I take your question is why to use excel for plotting, when SMath can do it just fine.
I am a very "visual" type of a designer. I would like to plot my struts and ties on top of a to-scale CAD drawing. In excel I can select background for the plot region. If the dimension of the imported background matches the X & Y ranges of the plot, the struts and ties overlay onto the CAD drawing to-scale; this will let me see any geometrical errors, inconsistencies etc.
Also I prefer prototyping my calcs in EXCEL, since if error is found they can be mass edited (Find/Replace).
thanks 1 user thanked Alex M. for this useful post.
on 03/03/2016(UTC)
Offline Alex M.
#30 Posted : 03 March 2016 22:11:44(UTC)
Alex M.
Thank you Davide :-) Should have figured that out myself, but hey... Blush
Alex, Smile
Thanks a lot for you answer.
Please believe me, no offense intention in my questions; if you received it, please apologize.
Honestly, I appreciated very much your engagement in doing plugins, courageously, starting as beginner.
In a trade work like ours, no models, everyone with his way. The shortest path between two points is the known one...
Of course we can learn from each other, and only this was my purpose, but finally we have or not to integrate things in our style.
Best Regards,
Ioan
Ioan,
I am more than happy to share my insight and would not take offence to a fair question Acute
We all have our own ways; luckily SMath is flexible enough to acommodate us all Crazy
I was going to use a modeller instead of a plot for strut&tie, but:
- plugin does not seem to work (not on my 0.97 version at home)
- Cannot set a scale / grid there
- cannot insert a background
thanks 2 users thanked Alex M. for this useful post.
on 03/03/2016(UTC),  on 03/03/2016(UTC)
Offline Alex M.
#31 Posted : 03 March 2016 22:15:06(UTC)
Alex M.
Alex, Smile
And as we say it here: there is as many correct solutions as the number of engineers you have asked. All of them are "best" in that person's opinion Cool
Edited by user 03 March 2016 22:26:03(UTC)  | Reason: Not specified
on 03/03/2016(UTC)
#32 Posted : 03 March 2016 22:19:22(UTC)
Don't worry (even if was a good occasion to use the RTFM smile RTFM) Laugh wild
Offline Ber7
#33 Posted : 04 March 2016 00:11:22(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
It works fine.
PrUgol adash.sm (67kb) downloaded 57 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 04/03/2016(UTC)
#34 Posted : 04 March 2016 21:23:09(UTC)
Hello Ioan Good
would be better to be conserved as visible after the lost focus event.
Unfortunately is not possible without drawbacks. I'll add a permanent internal label (alternative to this) when I'll add the label thicks. As for now the only way is to use a math object on the worksheet.
Also, I think it would be better to place the label on the free left side of the control.
Please excuse me if I abuse a little on your generosity.
You're excused. Top/Left sides can go on the edges of the worksheet, Top/Left/Right edges are available for the description region... this impacts both in the code as well as in the UI (the label would be placed not always in the same position - not necessirly bad, though is something to consider)
on 04/03/2016(UTC)
#35 Posted : 21 April 2016 17:11:15(UTC)
PLUGIN UPDATED SMath Studio 0.98.5952 Nightly Build only Beta
  • Added optional labels for ticks (maximum e minimum values);
  • Added optional label for current value;
  • "Settings..." item added to the context menu;
  • Several bug fixes related to wide ranges;
Edited by user 21 April 2016 17:19:40(UTC)  | Reason: Not specified
Offline Alex M.
#36 Posted : 21 April 2016 19:45:19(UTC)
Alex M.
David,
Since it looks like you are working on this plugin, may I suggest the following:
Add an ability to set a starting value of the slider from a worksheet.
It is useful when you use one slider to fine tune several independent values (by switching between them). It is also useful if the slider range, and starting point depend on the previous calculations, since it will change if the existing input changes.
Hope I am clear enough here. Thank you very much!
#37 Posted : 21 April 2016 20:11:39(UTC)
Integer values have limited use. The Microsoft "Scripted Component"
has the fractional capability, more useful in many instances of using.
Offline PompelmoTell
#38 Posted : 21 April 2016 20:19:10(UTC)
PompelmoTell
Jean,
in the documentation you can find how to use the "scale" parameter for non-integer values
on 21/04/2016(UTC)
#39 Posted : 21 April 2016 20:54:17(UTC)
I can do it, but this means that the slider will be used just as visual feedback, since any user change triggers the evaluation that restore the input value.
Unfortunately, nope; Microsoft's trackbar is based on integers (TrackBar.Value). Since I based the Viewer support on the Framework Trackbar, integers was the choice.
As mentioned by Sergio, I've implemented a scale factor to provide something better.
Edited by user 21 April 2016 21:39:15(UTC)  | Reason: Not specified
on 21/04/2016(UTC),  on 21/04/2016(UTC)
#40 Posted : 22 April 2016 03:29:10(UTC)
Hello: Sergio, Davide,
Thanks for your explanation. My comment was about something like the scripted components
supplied with Mathcad 11 [per say]. However, slider was for a guy like me developping 100's
model functions, vey useful to me but not in Engineering/Scientific works. In reference to
Mathcad 11 [per say again], Mathcad Scripted Components were almost unanimously rejected as
beeing "exe" [executable] thus, prone to virus/malware infection. Interesting for classroom
and for local animation and permanent animation to save, but unfortunately of very poor
quality no matter the codecs.
Cheers, Jean
on 22/04/2016(UTC)
3 Pages<123>
