Offline Alex M.
#1 Posted : 14 November 2016 02:49:07(UTC)
Alex M.
This example should be self explanatory. I expected same output in both cases. Is this a feature or a bug? Caused disaster in my formula logic.
Thanks!
FunctionBug.sm (8kb) downloaded 15 time(s).
#2 Posted : 14 November 2016 03:43:06(UTC)
Feature Good
You are using pass-by-reference, that assign a value to an input argument when it is the target of an assignment inside the procedure (see here f.e.)
2016-11-14 01_50_19-Feature or a bug_ Cannot force numeric evaluation within a function.png
the last assignment is missing; to assign the same value both to the result and to the input variable you have to define ID#:eval(ID#+1) even after the loop.
2016-11-14 01_53_10-2016-11-14 01_52_11-SMath Studio - [FunctionBug.sm_].png - Visualizzatore foto d.png
Edited by user 14 November 2016 03:56:48(UTC)  | Reason: Not specified
Offline Alex M.
#3 Posted : 14 November 2016 04:59:00(UTC)
Alex M.
Originally Posted by: Davide Carpi Go to Quoted Post
Feature Good
Davide, pass by reference assignment is intentional. What i do not understand is why
The result is 56 and not 10 - I used eval() to assign a static value to ID#, or so I thought, but ID# was assigned a dynamic ID# = ID# + 1, which was not the intent.
#4 Posted : 14 November 2016 05:20:37(UTC)
on 14/11/2016(UTC)
Offline mikekaganski
#5 Posted : 14 November 2016 06:53:25(UTC)
mikekaganski
Was thanked: 151 time(s) in 107 post(s)
Hey, in first block, you incremented ID by 1 in loop; in second you do it by self-incrementing i!
Best regards,
Mike Kaganski
thanks 2 users thanked mikekaganski for this useful post.
on 14/11/2016(UTC),  on 14/11/2016(UTC)
#6 Posted : 14 November 2016 08:12:24(UTC)
... more conveniently and generalised.
Maths SUM.sm (11kb) downloaded 15 time(s).
on 14/11/2016(UTC)
#7 Posted : 14 November 2016 10:42:09(UTC)
Ah! Now I see it.
This is the cause Good
Edited by user 15 November 2016 01:35:21(UTC)  | Reason: marked as solved
on 14/11/2016(UTC)
Offline Alex M.
#8 Posted : 14 November 2016 23:29:37(UTC)
Alex M.
Thank you all; so far I understood that something should be clear to me by now, but its not. What can I do to encapsulate a seemingly simple for() loop in a function that produces same result (10)?
FunctionBug1.sm (7kb) downloaded 11 time(s).
Offline omorr
#9 Posted : 14 November 2016 23:50:23(UTC)
omorr
Serbia
Hello Alex M.
I just hope that you did not see "1" - one instead if "i" in the loop.
Was that the problem or something else?
Offline Alex M.
#10 Posted : 15 November 2016 00:06:10(UTC)
Alex M.
Originally Posted by: omorr Go to Quoted Post
Hello Alex M.
I was blind as a mole. Thanks
Edited by user 15 November 2016 21:45:16(UTC)  | Reason: Not specified
#11 Posted : 15 November 2016 08:40:00(UTC)
I'm sure something I don't understand in there,
i.e: in what you are trying to do !
