SMath Studio Forum
Questions
Feature or a bug? Cannot force numeric evaluation within a function
This example should be self explanatory. I expected same output in both cases. Is this a feature or a bug? Caused disaster in my formula logic. Thanks! FunctionBug.sm (8kb) downloaded 15 time(s).
Feature You are using pass-by-reference, that assign a value to an input argument when it is the target of an assignment inside the procedure (see here f.e.) the last assignment is missing; to assign the same value both to the result and to the input variable you have to define ID#:eval(ID#+1) even after the loop. Edited by user 14 November 2016 03:56:48(UTC)
Originally Posted by: Davide Carpi Feature You are using pass-by-reference, that assign a value to an input argument when it is the target of an assignment inside the procedure (see here f.e.) the last assignment is missing; to assign the same value both to the result and to the input variable you have to define ID#:eval(ID#+1) even after the loop. Davide, pass by reference assignment is intentional. What i do not understand is why The result is 56 and not 10 - I used eval() to assign a static value to ID#, or so I thought, but ID# was assigned a dynamic ID# = ID# + 1, which was not the intent.
Joined: 17/01/2013(UTC) Posts: 296 Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Hey, in first block, you incremented ID by 1 in loop; in second you do it by self-incrementing i! |
Best regards, Mike Kaganski |
2 users thanked mikekaganski for this useful post.
on 14/11/2016(UTC), on 14/11/2016(UTC)
... more conveniently and generalised. Maths SUM.sm (11kb) downloaded 15 time(s).
Originally Posted by: Alex M. Davide, pass by reference assignment is intentional. What i do not understand is why The result is 56 and not 10 - I used eval() to assign a static value to ID#, or so I thought, but ID# was assigned a dynamic ID# = ID# + 1, which was not the intent. Ah! Now I see it. Originally Posted by: mikekaganski Hey, in first block, you incremented ID by 1 in loop; in second you do it by self-incrementing i! This is the cause Edited by user 15 November 2016 01:35:21(UTC)
| Reason: marked as solved |
Thank you all; so far I understood that something should be clear to me by now, but its not. What can I do to encapsulate a seemingly simple for() loop in a function that produces same result (10)? FunctionBug1.sm (7kb) downloaded 11 time(s).
Hello Alex M. I just hope that you did not see "1" - one instead if "i" in the loop. Was that the problem or something else? Regards, Radovan |
Originally Posted by: omorr Hello Alex M. I just hope that you did not see "1" - one instead if "i" in the loop. Was that the problem or something else? Regards, Radovan I was blind as a mole. Thanks Edited by user 15 November 2016 21:45:16(UTC)
I'm sure something I don't understand in there, i.e: in what you are trying to do !
SMath Studio Forum
Questions
