Offline studoc
#1 Posted : 16 December 2015 04:33:44(UTC)
studoc
Rank: Member
Looking for a little guidance..
I'm an engineer, and use Smath in structural design.
In doing so I often need to compare a calculated capacity to a design load.
Can anyone suggest an elegant method of reporting a "result", being: pass or: fail……?
thanks,
Stu.
Offline Ernesto
#2 Posted : 16 December 2015 07:36:16(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
One way is to use the conditionally formatted labels extension.
http://en.smath.info/for...ly-Formatted-Labels.aspx
Another is to present your results in table form using the table region.
http://en.smath.info/for...st1953_Table-Region.aspx
thanks 2 users thanked Ernesto for this useful post.
on 16/12/2015(UTC),  on 16/12/2015(UTC)
Offline csb531
#3 Posted : 16 December 2015 15:57:53(UTC)
csb531
Rank: Member
Netherlands
I use most of the time a very simple "if" condition.
No need for plug-ins and very easy to check for any reader.
By using indices you can also create a "table" with all "OK" an "FALSE" results. This can be convenient if you have different load cases with each one or more checks in a large document.
See the attached image.
Hope it is usefull for you!
Regards, csb.
Edited by user 16 December 2015 16:00:28(UTC)  | Reason: Not specified
Offline PompelmoTell
#4 Posted : 16 December 2015 22:40:29(UTC)
PompelmoTell
I am in agreement with CSB.
You can define a simple function to be used as needed
#5 Posted : 17 December 2015 07:58:17(UTC)
Interesting: that reminds me to instruct Smath about a "Truth table", like Mathcad.
Offline uncblue
#6 Posted : 17 December 2015 18:28:12(UTC)
uncblue
Rank: Member
This is how I typically show my utilization/stress ratios.
