Joined: 13/05/2011(UTC) Posts: 17 Location: coolum bch, Australia
Looking for a little guidance..
I'm an engineer, and use Smath in structural design.
In doing so I often need to compare a calculated capacity to a design load.
Can anyone suggest an elegant method of reporting a "result", being: pass or: fail……?
thanks,
Stu.
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
2 users thanked Ernesto for this useful post.
on 16/12/2015(UTC), on 16/12/2015(UTC)
Hello, I use most of the time a very simple "if" condition. No need for plug-ins and very easy to check for any reader. By using indices you can also create a "table" with all "OK" an "FALSE" results. This can be convenient if you have different load cases with each one or more checks in a large document. See the attached image. Hope it is usefull for you! Regards, csb. Edited by user 16 December 2015 16:00:28(UTC)
| Reason: Not specified
I am in agreement with CSB. You can define a simple function to be used as needed sergio
Interesting: that reminds me to instruct Smath about a "Truth table", like Mathcad.
Joined: 28/08/2013(UTC) Posts: 18 Was thanked: 2 time(s) in 2 post(s)
This is how I typically show my utilization/stress ratios.
