SMath Studio Forum
Questions
Why I am not getting output using Range
Was thanked: 8 time(s) in 7 post(s)
Hello, Why I am not getting output column? Thank you, Basile Basile attached the following image(s):
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
You cannot divide by a vector. You must use a for loop. Also you must properly define a function with a different variable than the one you will use inside the function afterwards. When I encounter issues in smath, I think it's best to put an equal sign after each step to show the result, it's easier to trace where the issues are. File Attachment(s): Ernesto attached the following image(s):
Ernesto, Thank you for the help but I am expecting the result to be a vector because I make a sweep. Basile
My mistake. I think this is what you were looking for. File Attachment(s): Ernesto attached the following image(s):
SMath Studio Forum
Questions
