Offline Basile
#1 Posted : 24 September 2015 22:51:55(UTC)
Basile
Was thanked: 8 time(s) in 7 post(s)
Why I am not getting output column?
Thank you,
Basile
Basile attached the following image(s):
Offline Ernesto
#2 Posted : 25 September 2015 02:16:24(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
You cannot divide by a vector. You must use a for loop. Also you must properly define a function with a different variable than the one you will use inside the function afterwards.
When I encounter issues in smath, I think it's best to put an equal sign after each step to show the result, it's easier to trace where the issues are.
File Attachment(s):
for loop example.sm (7kb) downloaded 10 time(s).
Ernesto attached the following image(s):
Offline Basile
#3 Posted : 25 September 2015 04:00:05(UTC)
Basile
Ernesto,
Thank you for the help but I am expecting the result to be a vector because I make a sweep.
Basile
Offline Ernesto
#4 Posted : 25 September 2015 06:56:26(UTC)
Ernesto
Nicaragua
My mistake. I think this is what you were looking for.
File Attachment(s):
for loop example.sm (8kb) downloaded 24 time(s).
Offline Basile
#5 Posted : 25 September 2015 11:01:43(UTC)
Basile
Yes,
Thank you,
Basile
