SMath Studio Forum
Feature Requests
Inversion of rectangular complex valued matrix
Many thanks to Andrey and the team for SMath Studio. You did a wonderful job.
I would like to add to the box of ideas an additional request. Let me explain the background.
When having mathematical problems which include solving of linear least squares proplems, like y=A*x where A is a complex valued matrix, x and y are complex valued vectors. A and y is known and the objective is to find a solution for x. Normaly the system is overdetermined then A is not a square matrix. The solution normaly given is x=(AT*A)^-1 * AT * y where AT is the complex conjugate of the transpose of A. (AT*A^) is a square matrix and can be inverted. However this solution is known as being sensitive to a bad conditoned matrix A. Unfortunately in practice this is often the case. With e.g. Matlab, there is a function called "pinv", which inverts non square matrices using a singular value decomposition (SVD) to achieve a numerically stable result.
I would think, having the SVD and the pinv could greatly enhance the possibilities of the Smath software in the direction of linear algebra.
Please comment.
SMath Studio Forum
Feature Requests
