Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
The snippet contains tables of operators and functions with special formatting and their corresponding keyboard input. This might be of help until these functions all made it into the side panel (feature request SS-202) There are some problems with the formatting of expressions in the tables, see SS-201Usage: - type "help" and press TAB - the tables are inserted in an area region - expand the area region and inspect the tables - if you are done, just collapse the region and delete it. Edited by user 09 August 2014 01:02:08(UTC)
| Reason: Not specified mkraska attached the following image(s): |
3 users thanked mkraska for this useful post.
on 09/08/2014(UTC), on 09/08/2014(UTC), on 09/08/2014(UTC)
Thank you Martin for this one By the way, I do not know if this was reported as a bug but if I try to move right with the bottom slider - unhandled exception occur. When expand the area, put the cursor below it (red cross), and try to move bottom slider. See this videoCould someone try to reproduce this. Unfortunately, I have the impression that using area regions looks like "walking on eggshells". Regards, Radovan Edited by user 09 August 2014 08:42:27(UTC)
Originally Posted by: smath Sorry Andrey. I forgot to uncheck the "Exclude closed issues" in searching the bugs report and did not find it. Anyway, thank you for fixing it Regards, Radovan |
