Offline mkraska
#1 Posted : 09 August 2014 00:45:22(UTC)
mkraska
Was thanked: 1126 time(s) in 723 post(s)
The snippet contains tables of operators and functions with special formatting and their corresponding keyboard input.
This might be of help until these functions all made it into the side panel (feature request SS-202)
There are some problems with the formatting of expressions in the tables, see SS-201
Usage:
- type "help" and press TAB - the tables are inserted in an area region
- expand the area region and inspect the tables
- if you are done, just collapse the region and delete it.
Edited by user 09 August 2014 01:02:08(UTC)  | Reason: Not specified
thanks 3 users thanked mkraska for this useful post.
on 09/08/2014(UTC),  on 09/08/2014(UTC),  on 09/08/2014(UTC)
Offline omorr
#2 Posted : 09 August 2014 08:37:10(UTC)
omorr
Serbia
Thank you Martin for this one Good
By the way, I do not know if this was reported as a bug but if I try to move right with the bottom slider - unhandled exception occur.
When expand the area, put the cursor below it (red cross), and try to move bottom slider.
See this video
Could someone try to reproduce this. Unfortunately, I have the impression that using area regions looks like "walking on eggshells".
Edited by user 09 August 2014 08:42:27(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#3 Posted : 09 August 2014 09:46:27(UTC)
Radovan,
This is the last Area related known issue (already fixed) and it is described here: http://smath.info/bts/Is.../IssueDetail.aspx?id=194
Offline omorr
#4 Posted : 09 August 2014 10:17:05(UTC)
omorr
Serbia
Originally Posted by: smath Go to Quoted Post
Radovan,
Sorry Andrey. I forgot to uncheck the "Exclude closed issues" in searching the bugs report and did not find it.
Anyway, thank you for fixing it Good
