  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,101   Was thanked: 972 time(s) in 557 post(s)
  Rank: Administration Groups: Registered, Administrators, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,735   Was thanked: 313 time(s) in 267 post(s)
It is amazing I have no experience in using this interesting product and, as I can notice, every function is working in SMath excluding the ones returning matrix or more than one value. Regards, Radovan |
Joined: 28/05/2020(UTC) Posts: 19  Location: Bartlesville, OK Was thanked: 4 time(s) in 2 post(s)
Hi uni,
I now have the MathcadEFI working. I put my prode.dll in the userefi folder. The test__ppp_1-2b.sm file does not run properly: all of the mc_xxxx functions are not defined.
Help please.
Unfortunately, the above links are out of date. Please attach your prode.dll to the post I'll see what I can do. As I can see, the current version of the distribution does not have this library. It would be better if you provide a previous version where both libraries were present: ppp.dll (32-bit) and prode.dll. Edited by user 30 May 2020 16:49:44(UTC)
Here are the dll files. prode.zip (209kb) downloaded 13 time(s). ppp.zip (3,044kb) downloaded 13 time(s).Edited by moderator 07 June 2020 18:39:03(UTC)
You must copy ppp.dll and prode.dll to the userefi folder and restart the program. After that you must point to some location when document opened. Code:Procedure:
1. Calculate the entire worksheet, ctrl-F9
2. Select dep.ppp archive when first window appears, and click Open
3. When second popup window, the Prode archive, appears, it should show stream 2. Click OK.
 I don't have this archive and this folder and I no longer remember what it is for. But now all functions are accessible.  When the program is running, you can see the list of loaded functions in the log file (mcadefi.log) in the folder with the plugin. Edited by user 30 May 2020 19:24:03(UTC)
I added the ppp.dll to userefi folder, but only kronecker and Psi show in the function list for EFI. I have restarted the SMath program and also disabled EFI and then enabled it an still no mc_xxxx functions.
I created the test_ppp file so I know how to use it.
Show me mcadefi.log file. It appears only when program is running. Edited by user 30 May 2020 20:09:33(UTC)
There is no mcadefi.log file. When you said earlier to restart the SMath program did you mean open the program or re-install the program?
Reopen I mean, try to reinstall the plugin using the Extension manager. The default path for plugin is: C:\Users\%user_name%\Application Data\SMath\extensions\plugins\91a20d24-c30b-4774-9b1b-4d502a80420f\x.x.x.x\ Edited by user 30 May 2020 20:34:48(UTC)
mcadef_logi.zip - Shortcut.lnk (3kb) downloaded 7 time(s).I found the efi files you mentioned but the path was different, and not where my SMath Studio is installed. Do I need to move them to the SMath Studio\plugins folder?
Sorry. That was a shortcut. Here is the log file. mcadef_logi.zip (1kb) downloaded 5 time(s).
It is not recommended to use SMath Studio\plugins folder. For a standard installation of the program, all extensions are installed in the above path.
As I can see, you are using an old version of the plugin (1.0.6982.32016, Tuesday, February 12, 2019 5:47:12 PM).
The last version is: 1.0.7165.40625, 14-aug-2019 22:34:10
I don't know why you are using SMath Studio\plugins folder. Try to download last SMath Studio and install the plugin in standard way - using Extension manager in main menu. After that - copy dlls to the plugin directory (not SMath Studio\plugins). Reopen the program and show me also \userefi\efi.txt file. |
Here's the actual path where I found the plugins. C:\Users\Harvey\AppData\Roaming\SMath\extensions\plugins Here's the path where my SMath program is currently installed: C:\Program Files (x86)\SMath Studio As I recall, I only got to say where the program was to be installed, not the plugins.
Before I start the re-installation process, I have a question: By Extension manager do you mean tools>plugins? I see no Extension manager.
Using this window  It is possible to create a plugin for SMath Studio and not to use such tricks. I mean the analogue for prode.dll for SMath Studio. Someday, if there is time. Edited by user 31 May 2020 00:55:22(UTC)
Originally Posted by: uni  As I can see, you are using an old version of the plugin (1.0.6982.32016, Tuesday, February 12, 2019 5:47:12 PM).
My version of the EFI plugin is the latest that the installer provides. The GOOD NEWS: Prode Phys. Properties works! The functions appear in the function list and the test file opens. There were some errors but I may be able to fix those. It appears that one problem is the SMath program doesn't recognize disabled math statements. That could explain some of the errors. Thank you so much for your prompt help.
As the author of the test file for the Prode Physical Properties dll, I have edited the SMath version of the test file to remove the errors. Many of the errors were due to one of the following: - converted index variable "i" to "i_" because in SMath "i" is used for imaginary
converted ranges to start with 1 instead of 0 insured that variable names were chosen properly using the dynamic edit option created plots in SMath form
Everything in the test file now works. In addition to using this file to ensure that Prode is installed properly, this file serves as a tutorial for use in SMath. I have attached the test file and its pdf version. Uni, it might be a good idea to replace these files in your initial post. test_ppp_1-2b.sm (308kb) downloaded 35 time(s). test_ppp_1-2b SMath.pdf (342kb) downloaded 47 time(s).Edited by moderator 02 June 2020 06:47:21(UTC)
 3 users thanked Harvey Hensley for this useful post.
on 02/06/2020(UTC), on 02/06/2020(UTC), on 02/06/2020(UTC)
Originally Posted by: Harvey Hensley  As the author of the test file for the Prode Physical Properties dll, I have edited the SMath version of the test file to remove the errors. If you have the source code for the prode.dll, then I could use them to create a plug-in for SMath Studio which will be 32- or 64-bit. |
Joined: 04/07/2015(UTC) Posts: 5,056  Was thanked: 809 time(s) in 642 post(s)
Originally Posted by: Harvey Hensley  I have attached the test file and its pdf version. SS 6179 does not open "wrong file format"
Originally Posted by: Jean Giraud  Originally Posted by: Harvey Hensley  I have attached the test file and its pdf version. SS 6179 does not open "wrong file format" What is SS 6179?
