2 Pages12>
Offline uni
#1 Posted : 22 June 2014 19:54:29(UTC)
uni
Prode Properties
SMath Studio compatibility Platform SMath Viewer compatibility mono compatibility Extension page Sources
Prode Properties must be installed or copied (ppp.dll and pppx.dll) to the directory of plugin. The chemical database should be in the folder where the application will look for it. This may vary by version.
Protected оriginal installer (p/w: friend): Prode Properties 1.2d1.exe.7z (14,166kb) downloaded 54 time(s).
Unpacked оriginal installer: Prode1.2d1free.7z (11,036kb) downloaded 79 time(s).
Prode Properties. Technical features overview (Windows version).pdf (55kb) downloaded 44 time(s).
Prode Properties 1.2. User Manual.pdf (8,937kb) downloaded 96 time(s).
Note. You must delete the prode library (prode.dll) if it was previously used in the mcadefi plugin.
Links:
1. Prode download Area
Examples:
test_ppp_1-2b.sm (308kb) downloaded 67 time(s).
test_ppp_1-2b SMath.pdf (342kb) downloaded 69 time(s).
Edited by user 19 June 2020 10:56:19(UTC)  | Reason: Not specified
File Attachment(s):
test_ppp_1-2b.sm (255kb) downloaded 125 time(s).
test_ppp_1-2b_mc15.pdf (104kb) downloaded 87 time(s).
test_ppp_1-2b_smath.pdf (103kb) downloaded 118 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 23/06/2014(UTC)
Offline omorr
#2 Posted : 23 June 2014 12:49:58(UTC)
omorr
Serbia
It is amazing Shok
I have no experience in using this interesting product and, as I can notice, every function is working in SMath excluding the ones returning matrix or more than one value.
Offline Harvey Hensley
#3 Posted : 30 May 2020 16:03:47(UTC)
Harvey Hensley
Rank: Member
Was thanked: 4 time(s) in 2 post(s)
Hi uni,
I now have the MathcadEFI working. I put my prode.dll in the userefi folder. The test__ppp_1-2b.sm file does not run properly: all of the mc_xxxx functions are not defined.
Help please.
Offline uni
#4 Posted : 30 May 2020 16:25:03(UTC)
uni
Unfortunately, the above links are out of date. Please attach your prode.dll to the post I'll see what I can do. As I can see, the current version of the distribution does not have this library. It would be better if you provide a previous version where both libraries were present: ppp.dll (32-bit) and prode.dll.
Edited by user 30 May 2020 16:49:44(UTC)  | Reason: Not specified
Russia ☭ forever
#5 Posted : 30 May 2020 18:40:48(UTC)
Harvey Hensley
Rank: Member
Here are the dll files.
prode.zip (209kb) downloaded 24 time(s).
ppp.zip (3,044kb) downloaded 25 time(s).
Edited by moderator 07 June 2020 18:39:03(UTC)  | Reason: Not specified
Offline uni
#6 Posted : 30 May 2020 19:11:49(UTC)
uni
You must copy ppp.dll and prode.dll to the userefi folder and restart the program. After that you must point to some location when document opened.
Code:
Procedure:
1. Calculate the entire worksheet, ctrl-F9
2. Select dep.ppp archive when first window appears, and click Open
3. When second popup window, the Prode archive, appears, it should show stream 2. Click OK.
I don't have this archive and this folder and I no longer remember what it is for. But now all functions are accessible.
When the program is running, you can see the list of loaded functions in the log file (mcadefi.log) in the folder with the plugin.
Edited by user 30 May 2020 19:24:03(UTC)  | Reason: Not specified
Russia ☭ forever
#7 Posted : 30 May 2020 19:55:38(UTC)
Harvey Hensley
Rank: Member
I added the ppp.dll to userefi folder, but only kronecker and Psi show in the function list for EFI. I have restarted the SMath program and also disabled EFI and then enabled it an still no mc_xxxx functions.
I created the test_ppp file so I know how to use it.
Offline uni
#8 Posted : 30 May 2020 20:07:06(UTC)
uni
Show me mcadefi.log file. It appears only when program is running.
Edited by user 30 May 2020 20:09:33(UTC)  | Reason: Not specified
Russia ☭ forever
#9 Posted : 30 May 2020 20:15:18(UTC)
Harvey Hensley
Rank: Member
There is no mcadefi.log file. When you said earlier to restart the SMath program did you mean open the program or re-install the program?
Offline uni
#10 Posted : 30 May 2020 20:28:45(UTC)
uni
Reopen I mean, try to reinstall the plugin using the Extension manager.
The default path for plugin is: C:\Users\%user_name%\Application Data\SMath\extensions\plugins\91a20d24-c30b-4774-9b1b-4d502a80420f\x.x.x.x\
Edited by user 30 May 2020 20:34:48(UTC)  | Reason: Not specified
Russia ☭ forever
on 31/05/2020(UTC)
#11 Posted : 30 May 2020 20:54:43(UTC)
Harvey Hensley
Rank: Member
mcadef_logi.zip - Shortcut.lnk (3kb) downloaded 12 time(s).
I found the efi files you mentioned but the path was different, and not where my SMath Studio is installed. Do I need to move them to the SMath Studio\plugins folder?
#12 Posted : 30 May 2020 21:03:41(UTC)
Harvey Hensley
Rank: Member
Sorry. That was a shortcut. Here is the log file.
mcadef_logi.zip (1kb) downloaded 11 time(s).
Offline uni
#13 Posted : 30 May 2020 21:14:59(UTC)
uni
It is not recommended to use SMath Studio\plugins folder. For a standard installation of the program, all extensions are installed in the above path.
As I can see, you are using an old version of the plugin (1.0.6982.32016, Tuesday, February 12, 2019 5:47:12 PM).
The last version is: 1.0.7165.40625, 14-aug-2019 22:34:10
I don't know why you are using SMath Studio\plugins folder. Try to download last SMath Studio and install the plugin in standard way - using Extension manager in main menu.
After that - copy dlls to the plugin directory (not SMath Studio\plugins). Reopen the program and show me also \userefi\efi.txt file.
Russia ☭ forever
on 31/05/2020(UTC)
#14 Posted : 30 May 2020 22:02:07(UTC)
Harvey Hensley
Rank: Member
Here's the actual path where I found the plugins. C:\Users\Harvey\AppData\Roaming\SMath\extensions\plugins
Here's the path where my SMath program is currently installed: C:\Program Files (x86)\SMath Studio
As I recall, I only got to say where the program was to be installed, not the plugins.
Before I start the re-installation process, I have a question: By Extension manager do you mean tools>plugins? I see no Extension manager.
Offline uni
#15 Posted : 30 May 2020 22:44:57(UTC)
uni
Using this window
It is possible to create a plugin for SMath Studio and not to use such tricks. I mean the analogue for prode.dll for SMath Studio. Someday, if there is time.
Edited by user 31 May 2020 00:55:22(UTC)  | Reason: Not specified
Russia ☭ forever
on 31/05/2020(UTC)
#16 Posted : 31 May 2020 01:50:47(UTC)
Harvey Hensley
Rank: Member
My version of the EFI plugin is the latest that the installer provides.
The GOOD NEWS: Prode Phys. Properties works! The functions appear in the function list and the test file opens. There were some errors but I may be able to fix those. It appears that one problem is the SMath program doesn't recognize disabled math statements. That could explain some of the errors.
Thank you so much for your prompt help.
#17 Posted : 02 June 2020 01:03:02(UTC)
Harvey Hensley
Rank: Member
As the author of the test file for the Prode Physical Properties dll, I have edited the SMath version of the test file to remove the errors. Many of the errors were due to one of the following:
  • converted index variable "i" to "i_" because in SMath "i" is used for imaginary
    converted ranges to start with 1 instead of 0
    insured that variable names were chosen properly using the dynamic edit option
    created plots in SMath form
Everything in the test file now works. In addition to using this file to ensure that Prode is installed properly, this file serves as a tutorial for use in SMath.
I have attached the test file and its pdf version. Uni, it might be a good idea to replace these files in your initial post.
Edited by moderator 02 June 2020 06:47:21(UTC)  | Reason: Not specified
thanks 3 users thanked Harvey Hensley for this useful post.
on 02/06/2020(UTC),  on 02/06/2020(UTC),  on 02/06/2020(UTC)
Offline uni
#18 Posted : 02 June 2020 07:46:19(UTC)
uni
If you have the source code for the prode.dll, then I could use them to create a plug-in for SMath Studio which will be 32- or 64-bit.
Russia ☭ forever
on 02/06/2020(UTC)
Offline uni
#19 Posted : 05 June 2020 00:26:06(UTC)
uni
Updated. Prode Physical Properties must be installed or copied (ppp.dll and pppx.dll) to the directory of plugin.
Changes:
- support 32 and 64-bit modes;
- dynamic function binding (only existing functions are available);
- library search paths are hardcoded: C:\Program Files\Prode\LIB\64;C:\Program Files\Prode\LIB\32;plugin directory.
Russia ☭ forever
on 07/06/2020(UTC)
Offline uni
#20 Posted : 07 June 2020 14:01:44(UTC)
uni
Updated. Tested with Prode Properties 1.2d1 Free version.
Changes:
- source code refactored.
Edited by user 07 June 2020 17:53:29(UTC)  | Reason: Not specified
Russia ☭ forever
on 08/06/2020(UTC)
Guest (2)
2 Pages12>
