Offline fakemoses
#1 Posted : 31 July 2023 20:09:47(UTC)
fakemoses
Rank: Member
Was thanked: 15 time(s) in 7 post(s)
Hello everyone,
I've been trying to implement the toolbox feature for the maxima plugin that I am currently working on. The example that I am following is from Davide Carpi
https://smath.info:8443/!/#public/view/head/plugins/CustomFunctions/Toolbox.cs
When implementing ButtonsMetaData[] part, it shows me an error "ButtonsMetaData.ButtonsMetaData()" is inaccessible due to its protection level. Any idea on what did I do wrong or way to fix this?
Muiz
thanks 1 user thanked fakemoses for this useful post.
on 01/08/2023(UTC)
#2 Posted : 01 August 2023 08:42:18(UTC)
Was thanked: 1339 time(s) in 878 post(s)
I'm not sure that the Toolbox code in Custom Functions is updated to the latest API changes, since that feature is not activated there;
please check one of the following:
You might find the latter more interesting since implements also the SVG rendering.
Edited by user 01 August 2023 09:48:37(UTC)  | Reason: Typo
on 01/08/2023(UTC),  on 01/08/2023(UTC)
Offline Kenny Lemens
#3 Posted : 04 August 2023 01:06:42(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
I vaguely remember having a similar issue. I program in VB.NET, so part of my issue was converting code from C# to VB.NET, but I'll rattle off some items:
  • Make sure you set up your class correctly; 「Implements」 IPluginToolboxGroups instead of 「Inherits」 or 「Delegate」 or 「Shared」
  • Subs/Functions/Variables must use appropriate permissions; I think I had some as 「Private」 or 「Protected」, but had to use 「Public」 ¿Maybe?
  • I broke up my ButtonsMetaData declarations; instead of having an inline statement like you, I created an object and then modified the properties; I remember having some trouble getting an inline statement to work...
    Code:
          Dim btnButtonA2 As ButtonsMetaData = New ButtonsMetaData(" Δ°F ")
          btnButtonA2.Action = "'Δ°F"
          btnButtonA2.Description = "Degrees Fahrenheit, Difference of"
    Code:
          Dim toolGrp_A As ToolboxGroup = New ToolboxGroup()
          toolGrp_A.Title = "Engineering Toolbar"
          toolGrp_A.Buttons = {btnButtonA1, btnButtonA2, btnButtonA3}
          Return (New ToolboxGroup() {toolGrp_A})
As a final note (for what its worth): this is the class I am using:
Code:
SMath.Manager.ButtonsMetaData
Your problem may be the "ButtonsMetaData.ButtonsMetaData()".
I'm using v0.99 so that may also be an item to note between us.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
thanks 2 users thanked Kenny Lemens for this useful post.
on 04/08/2023(UTC),  on 04/08/2023(UTC)
