SMath Studio Forum
Questions
Error implementing ToolboxGroup for the maxima plugin
Joined: 10/04/2023(UTC) Posts: 22 Was thanked: 15 time(s) in 7 post(s)
Hello everyone, I've been trying to implement the toolbox feature for the maxima plugin that I am currently working on. The example that I am following is from Davide Carpi https://smath.info:8443/!/#public/view/head/plugins/CustomFunctions/Toolbox.csWhen implementing ButtonsMetaData[] part, it shows me an error "ButtonsMetaData.ButtonsMetaData()" is inaccessible due to its protection level. Any idea on what did I do wrong or way to fix this? Regards, Muiz
1 user thanked fakemoses for this useful post.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,651 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
I'm not sure that the Toolbox code in Custom Functions is updated to the latest API changes, since that feature is not activated there; please check one of the following: You might find the latter more interesting since implements also the SVG rendering. Edited by user 01 August 2023 09:48:37(UTC)
| Reason: Typo |
on 01/08/2023(UTC), on 01/08/2023(UTC)
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, I vaguely remember having a similar issue. I program in VB.NET, so part of my issue was converting code from C# to VB.NET, but I'll rattle off some items: - Make sure you set up your class correctly; 「Implements」 IPluginToolboxGroups instead of 「Inherits」 or 「Delegate」 or 「Shared」
- Subs/Functions/Variables must use appropriate permissions; I think I had some as 「Private」 or 「Protected」, but had to use 「Public」 ¿Maybe?
- I broke up my ButtonsMetaData declarations; instead of having an inline statement like you, I created an object and then modified the properties; I remember having some trouble getting an inline statement to work...
Code:
Dim btnButtonA2 As ButtonsMetaData = New ButtonsMetaData(" Δ°F ")
btnButtonA2.Action = "'Δ°F"
btnButtonA2.Description = "Degrees Fahrenheit, Difference of"
Code:
Dim toolGrp_A As ToolboxGroup = New ToolboxGroup()
toolGrp_A.Title = "Engineering Toolbar"
toolGrp_A.Buttons = {btnButtonA1, btnButtonA2, btnButtonA3}
Return (New ToolboxGroup() {toolGrp_A})
As a final note (for what its worth): this is the class I am using: Code:SMath.Manager.ButtonsMetaData
Your problem may be the "ButtonsMetaData.ButtonsMetaData()". I'm using v0.99 so that may also be an item to note between us. May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
2 users thanked Kenny Lemens for this useful post.
on 04/08/2023(UTC), on 04/08/2023(UTC)
SMath Studio Forum
Questions
