Offline ioncube
#1 Posted : 19 February 2023 21:03:43(UTC)
ioncube
Pakistan
In my plant 20 pumps require flush water which is supplied by a close circuit water flow network. Flush rate & max temperature rise are per vendor specifications. Hot purge & simultaneous volume makeup by fresh water is what maintains the temperature.
I am attaching my solution to the problem. I further need to have multiple plots (on same graph) which corresponds to different temperature rises indicated by equation defining Tc. Please advice
FlushWater_updatedCoolProp2.sm (83kb) downloaded 14 time(s).
Edited by user 20 February 2023 00:16:47(UTC)  | Reason: Not specified
Online Razonar
#2 Posted : 20 February 2023 09:48:32(UTC)
Razonar
Uruguay
Was thanked: 834 time(s) in 528 post(s)
Hi. Maybe, something like this?
FlushWater_updatedCoolProp2.sm (93kb) downloaded 19 time(s).
Offline ioncube
#3 Posted : 20 February 2023 19:58:31(UTC)
ioncube
Pakistan
This should have worked ...the data dimensions are correct
#4 Posted : 20 February 2023 20:13:36(UTC)
Offline ioncube
#5 Posted : 21 February 2023 01:24:07(UTC)
ioncube
Pakistan
I am waiting for a heat exchanger (with temperature loop) which will take x3 months. In the meantime I want to use make up water for temperature control by hot bleeding. Bleeded stream will not be wasted & goes to Cooling Tower makeup ...
Jean, can we use solve() command somehow?
#6 Posted : 21 February 2023 01:48:43(UTC)
Better wait the heat exchanger c/w control loop.
Detail: most likely the control algorithm will be Lead/Lag.
Your document is red. I will revisit.
In my native SS 6179, if CoolProp is used in another document
it can be called from another document ... a damned bug.
#7 Posted : 21 February 2023 02:49:41(UTC)
No luck, your document is red with 1 page long error message.
You are trying to plot something, tabulate the data set.
From there, no problem to fit/solve.
#8 Posted : 21 February 2023 16:41:28(UTC)
Revisit the heat exchanger LMTD.
Inst_LMTD.sm (33kb) downloaded 3 time(s).
Offline ioncube
#9 Posted : 21 February 2023 19:56:08(UTC)
ioncube
Pakistan
Mr. Jean thanks for your input but we will be using Plate & Frame heat exchnagers which design is very differnt from tubular exchangers.
Now I have x2 matrices (ranges) changing TB (5 values) which plot a curve at changing TC (3 values) ...so we have x3 curves. Can you change attached file to my requirement
FlushWater_updatedCoolProp3.sm (90kb) downloaded 7 time(s).
#10 Posted : 22 February 2023 00:33:53(UTC)
Sorry Collab, your document is red in native SS 6179.
My understanding follows.
FlushWater_updatedCoolProp3.sm (99kb) downloaded 4 time(s).
Offline ioncube
#11 Posted : 22 February 2023 13:53:15(UTC)
ioncube
Pakistan
Jean, because CoolProp addin is not installed (I am also using secant() from nonlinear addin) thats why its throwing error. Check the pdf. Any recommendations from your side
Flush Water.pdf (360kb) downloaded 7 time(s).
#12 Posted : 22 February 2023 15:47:26(UTC)
Nice PDF ... can you make it an Smath document for checking.
CoolProp is an old vintage. Mike helped a lot, as well Alvaro.
I don't use ... rather WASP from Mathcad 11 coded Smath.
By same token, Katmar WASP is freeware for 5 minutes per use.
Once you have your [°C ... kJ/kg] data, you can resume the project.
Most interesting ,,, Cheers ... Jean.
FlushWater_updatedCoolProp3 RESUMED Version.sm (10kb) downloaded 3 time(s).
Offline ioncube
#13 Posted : 22 February 2023 18:24:05(UTC)
ioncube
Pakistan
Jean, Thnaks for your plot() function. Here is the .sm file. Being a chemical engineer I cannot let go of CoolProp bcz besides water I have to deal with many gases like N2, air, Cl2, CO2 ...so its vital for me. Additionally, I have seen here that Prode Properties is being used as an Smath addin I will certainly try to make it work bcz I have already integrated it in Excel
FlushWater_final_old.sm (97kb) downloaded 5 time(s).
#14 Posted : 23 February 2023 17:38:03(UTC)
For convenience, I have added bilinear interpolation.
FlushWater_updatedCoolProp3 RESUMED Version.sm (22kb) downloaded 6 time(s).
