SMath Studio Forum
Download SMath Studio
Stable: SMath Studio 1.0.8253 (06 August 2022)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,598   Was thanked: 1953 time(s) in 658 post(s)
New Stable SMath Studio 1.0.8253 is available!Tiny, but powerful mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- Doubleclick on the unit placeholder (at right-hand side of the calculation result) opens Insert Unit dialog with suggested dimension now;
- Go to Definition command opens Insert Unit dialog with unit/dimension details when applicable now;
- Units dialog improved to display unit definition;
- Approximately not equal operator implemented.
Corrections- Closing of the Worksheet when file saving is required fixed;
- Observations happens in some cases with Approximately Equal operator when comparing small numbers fixed;
- Command line functionality restored.
Miscellaneous- Window with empty Worksheet is now automatically closed on open a file (no empty documents are generated now);
- Refactoring.
DownloadSystem requirements - Desktop (Windows):
- Desktop (Linux):
Interface languages (37 languages) - [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
Tutorial SMath Studio tutorial by Bernard Liengme. SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons (  ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
 7 users thanked Andrey Ivashov for this useful post.
on 06/08/2022(UTC), on 06/08/2022(UTC), on 06/08/2022(UTC), on 06/08/2022(UTC), on 06/08/2022(UTC), on 06/08/2022(UTC), on 10/08/2022(UTC)
Joined: 05/03/2009(UTC) Posts: 431   Location: USA Was thanked: 17 time(s) in 15 post(s)
Thank you. I haven't been here much, but always support and appreciate the work that has gone into this project. So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available...
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,503   Location: Italy Was thanked: 1257 time(s) in 827 post(s)
Originally Posted by: ElSid  Thank you. I haven't been here much, but always support and appreciate the work that has gone into this project. So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available... The "don't check for updates" checkbox is unchecked? ![2022-08-09 17_44_43-SMath Solver - [Worksheet1].png](/forum/resource.ashx?a=45197&b=2) Edited by user 09 August 2022 19:40:21(UTC)
| Reason: Typo |
Originally Posted by: Davide Carpi  The "don't check for updates" checkbox is unchecked? Davide, That is correct. This is for the portable version. Looks like Andrey posted 4 days ago and I was the first comment ... maybe others didn't get the update pop-up message on their full install as well. Time to reload my OSesesesese.
Привет Андрей! Я хотел бы использовать в расчётах момент, но до сих пор не нашёл. Положи пожалуйста в SMath (изгибающий момент, вращающий момент, крутящий момент - единицы 'Nm' и 'kNm'  . Я нашёл ещё ошибку в венгерском языке, 'Ellenálás' не правильно, надо писать 'Ellenállás' (по-русски сопротивление). Kaderász Péter
Joined: 15/04/2012(UTC) Posts: 1,736  Was thanked: 952 time(s) in 604 post(s)
Пока момента в списке единиц нет, можете использовать составленные единицы: 'N*'m. Мне также неудобно что всегда нужно ручно изменить J на. 'N*'m. Но так и будет при наличии 'Nm т.к. это вряд ли хорошая единица по умольчанию для всяких величин размерности сила на длину. Скорее вчего для большинства имеется в виду работа или энергия. |
Привет Мартин! Я уже несколько лет пишу в первый ряд на невидную область дефиницию момента:  Потом я могу использовать Nm. Kaderász Péter
SMath Studio Forum
