Offline ianlh
#1 Posted : 09 December 2021 15:10:03(UTC)
ianlh
I am trying to convert a Mathcad 15 sheet, and have a problem with the below equation:
Is there a summation within Smath that will do the second summation?
From the Mathcad help:
Thanks in advance
Ian
Offline Razonar
#2 Posted : 09 December 2021 18:33:55(UTC)
Razonar
Uruguay
Hi. There are not equivalent, but this is how to convert it into usual summation operator.
Offline ianlh
#3 Posted : 10 December 2021 11:15:00(UTC)
ianlh
Still cant get it to work, I will strip out the identifying material and post the worksheet.
Thanks
Ian
Offline ianlh
#4 Posted : 10 December 2021 13:12:21(UTC)
ianlh
Attached is sheet, this is a MRM for beam frequency analysis
natural freq 5 v2 forum.sm (59kb) downloaded 17 time(s).
#5 Posted : 10 December 2021 14:18:09(UTC)
Sum over 'n' ... NOT over 'k'
Model summation attached.
Function Running Summation.sm (33kb) downloaded 10 time(s).
Online uni
#6 Posted : 10 December 2021 14:39:51(UTC)
uni
Better to attach the original Mathcad document.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline ianlh
#7 Posted : 10 December 2021 17:24:34(UTC)
ianlh
Mathcad sheet attached, striped version
beam frequency test 2.xmcd (172kb) downloaded 10 time(s).
Jean, I am at a loss as to which part of your file I should be looking at.
Ian
Offline Razonar
#8 Posted : 10 December 2021 17:48:32(UTC)
Razonar
Uruguay
Hi. As Viacheslav says, it's better in this case the mathcad file. Just a couple of notes.
You use a for loop with i as counter. Thus, at the exit, i equals the last count value, not the entire range. So, or you redefine i as range, or use this way for not changing i value
Actually, SMath doesn't have "range" variables, it only have scalars and matrices. But mathcad have "true" range variables, which it's more a complication than an adventage. BTW in SMath you can't use a range variable in the same way, and sometimes needs some dummy variable for detect them
Finally, remember that in mathcad sqrt(-1) is 1i, but in SMath it is just i, so using is as counter you loose all the complex algebra.
Bests regards.
#9 Posted : 10 December 2021 18:30:05(UTC)
It just shows how to run summation wrt several dependent functions.
Offline ianlh
#10 Posted : 10 December 2021 19:33:41(UTC)
ianlh
Hi Alvaro,
Some interesting hints there. I imagine its also the same going the other way.
Hi Jean,
OK, now I understand, just some pointers for me
Thanks
Ian
#11 Posted : 10 December 2021 19:46:48(UTC)
Hi Jean,
Thanks
Ian
The A,B are numerical two vectors of coefficients.
Then introduced in the scalar function wrt sin/cos.
Online uni
#12 Posted : 10 December 2021 21:00:17(UTC)
uni
I think that there should be such a replacement.
Russia ☭ forever
Online uni
#13 Posted : 10 December 2021 21:09:11(UTC)
uni
You can use debugging in both programs to check that the functions are working correctly.
Click to enlarge
Russia ☭ forever
Offline ianlh
#14 Posted : 10 December 2021 21:50:04(UTC)
ianlh
Thanks for the pointers, will revisit tomorrow
Ian
