Offline gurro
#1 Posted : 15 August 2021 00:14:03(UTC)
gurro
Was thanked: 19 time(s) in 7 post(s)
Offline mkraska
#2 Posted : 16 August 2021 21:26:04(UTC)
mkraska
Was thanked: 1045 time(s) in 670 post(s)
Thank you for reporting the issue. Could you please attach your .sm file to your post?
The problems seem to originate from the internal character encoding used by SMath Studio. The interface to Maxima and Maxima itself are unicode proof (as long SBCL is used). So there is no need for such encoding from my side and at development time of the plugin there was no such encoding.
I need to check if that encoding can be switched off or decoded within the plugin.
@developers: any recommendation on how to proceed?
A temporary mitigation could be adding a translation function in maxima.xml in the plugin directory. Some hints on how to setup custom translations or functions from user side are found in the german pdf handbook, online translators seem to produce pretty usable english versions.
#3 Posted : 16 August 2021 22:03:12(UTC)
Was thanked: 1300 time(s) in 856 post(s)
To decode SMath text and variables/functions names to unicode strings, you have to use:
Code:
TermsConverter.DecodeText(text);
The opposite can be done with
Code:
TermsConverter.EncodeText(text);
Offline Engr
#4 Posted : 20 August 2021 17:23:23(UTC)
Engr
Rank: Member
Was thanked: 8 time(s) in 4 post(s)
The same issue is also occurring in the "Excel (2003+) I/O with recalculation and PNG export" plugin. See the Smath Studio and Excel screen shots below for an example.
Would it be possible to fix the plug-in?
Thanks
engr
Offline DiegoV
#5 Posted : 15 June 2022 09:18:14(UTC)
DiegoV
Costa Rica
I have the same issue and adding a translation function in maxima.xml in the plugin directory is not working. Can you anyone help us to make it right?
