Offline E-Jay
#1 Posted : 16 October 2013 18:27:48(UTC)
E-Jay
Rank: Member
Was thanked: 3 time(s) in 2 post(s)
I would simply like to define a vector, then apply a operation to each element and have the results in a second vector. This seems to be simple in MathCad but I can't seem to get it in SMath Studio.
In MathCad
In SMath Studio I get this. I'm not shre just what this result is.
Any assistance would be appreciated.
Thank you.
Offline mb10
#2 Posted : 16 October 2013 18:46:45(UTC)
mb10
Rank: Member
Was thanked: 9 time(s) in 5 post(s)
The result is the sum of the squares of the elements, multiplied by two.
As far as I know SMath does not support vectorization (yet) so, in order to obtain what you need, you should use a for loop.
Offline omorr
#3 Posted : 16 October 2013 19:01:48(UTC)
omorr
Serbia
If you are using vectors, then you can try mat2sys() and sys2mat()
Offline E-Jay
#4 Posted : 16 October 2013 20:35:36(UTC)
E-Jay
Rank: Member
Thank you mb10, I got the For..Loop to work it out. I was wondering if the vector options were available or not.
To omorr, the mat2sys() and sys2ma() looks like a clean method to acheive these functionality but how do I add the mat2sys() and sys2mat() functions?
Thank you.
Offline mkraska
#5 Posted : 16 October 2013 23:46:28(UTC)
mkraska
mat2sys and sys2mat are part of the CustomFunctions plugin by Davide Carpi. You can install it using the extension manager (Tools> Plugins) or use the unofficial distribution with pre-installed plugins (link in the signature).
You also might consider using the Maxima Plugin (which requires Maxima to be installed on your system)
Edited by user 16 October 2013 23:51:01(UTC)  | Reason: Not specified
on 17/10/2013(UTC)
