SMath Studio Forum
Questions
define one vector from another
Joined: 15/08/2013(UTC) Posts: 10 Location: Alliance, Ohio Was thanked: 3 time(s) in 2 post(s)
I would simply like to define a vector, then apply a operation to each element and have the results in a second vector. This seems to be simple in MathCad but I can't seem to get it in SMath Studio. In MathCad In SMath Studio I get this. I'm not shre just what this result is. Any assistance would be appreciated. Thank you.
Joined: 27/08/2013(UTC) Posts: 19 Was thanked: 9 time(s) in 5 post(s)
The result is the sum of the squares of the elements, multiplied by two. As far as I know SMath does not support vectorization (yet) so, in order to obtain what you need, you should use a for loop.
If you are using vectors, then you can try mat2sys() and sys2mat() Regards, Radovan omorr attached the following image(s): |
Thank you mb10, I got the For..Loop to work it out. I was wondering if the vector options were available or not.
To omorr, the mat2sys() and sys2ma() looks like a clean method to acheive these functionality but how do I add the mat2sys() and sys2mat() functions?
Thank you.
mat2sys and sys2mat are part of the CustomFunctions plugin by Davide Carpi. You can install it using the extension manager (Tools> Plugins) or use the unofficial distribution with pre-installed plugins (link in the signature). You also might consider using the Maxima Plugin (which requires Maxima to be installed on your system) Edited by user 16 October 2013 23:51:01(UTC)
| Reason: Not specified mkraska attached the following image(s): |
SMath Studio Forum
Questions
