Offline mkraska
#1 Posted : 29 August 2013 20:21:44(UTC)
mkraska
In the 2D plot region, I observed a tick label (number) to switch from the correct value (8) to zero for special scaling values. Even if there is XY-Plot region if nice labeling matters, this might be worth a fix.
Offline omorr
#2 Posted : 29 August 2013 23:56:21(UTC)
omorr
Serbia
Hmm...can not reproduce this,
#3 Posted : 30 August 2013 00:52:22(UTC)
Is not a bug, just an eye-trick due to a combination of font-size, line thickness and line position; if you move the grid or you zoom your page you can see the trick (plot not evaluated)
best regards,
Davide
Edited by user 30 August 2013 00:54:20(UTC)  | Reason: Not specified
on 30/08/2013(UTC)
Offline mkraska
#4 Posted : 30 August 2013 04:32:11(UTC)
mkraska
Thanks for pointing this out. Then the remedy is easy: change the z-order of the objects (grid to bottom). I did not note that the grid is in front of the tick labels.
#5 Posted : 30 August 2013 13:55:02(UTC)
I agree, should be the easiest solution Good
