In the 2D plot region, I observed a tick label (number) to switch from the correct value (8) to zero for special scaling values. Even if there is XY-Plot region if nice labeling matters, this might be worth a fix. mkraska attached the following image(s): |
Hmm...can not reproduce this, Regards, Radovan omorr attached the following image(s): |
Is not a bug, just an eye-trick due to a combination of font-size, line thickness and line position; if you move the grid or you zoom your page you can see the trick (plot not evaluated) best regards, Davide Edited by user 30 August 2013 00:54:20(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Originally Posted by: w3b5urf3r_reloaded Is not a bug, just an eye-trick due to a combination of font-size, line thickness and line position; if you move the grid or you zoom your page you can see the trick Thanks for pointing this out. Then the remedy is easy: change the z-order of the objects (grid to bottom). I did not note that the grid is in front of the tick labels. |
Originally Posted by: mkraska Thanks for pointing this out. Then the remedy is easy: change the z-order of the objects (grid to bottom). I did not note that the grid is in front of the tick labels. I agree, should be the easiest solution |
