  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,314   Was thanked: 1147 time(s) in 662 post(s)
 Plugin updated. Changes: - solution restructured; - converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed; - refactored. Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin. Edited by user 20 December 2021 22:15:22(UTC)
 Updated. Changes: - updated to GSL 2.7; - gsl_version operand added; - refactored. |
 Updated. Changes: - gsl_sf() function added (only airy supported); - totally refactored. The library has a huge number of functions, but it is very difficult to find a convenient method for calling them. I decided to try one method, calling special functions with one generic function and a combination of flags.  Edited by user 25 December 2021 00:27:51(UTC)
Плагин установлен и виден в SMath, но ни одна его функция не доступна. В чем может быть дело? The plugin is installed and visible in SMath, but none of its functions are available. What can be wrong? Windows 10 Home x64 21H1, SMathStudioDesktop portable (mono).  Upd: Разобрался. Нужен Microsoft Visual C++ 2015 Redistributable. Understood. Requires Microsoft Visual C++ 2015 Redistributable. https://www.microsoft.co...ad/details.aspx?id=53840Edited by user 01 February 2022 16:19:59(UTC)
| Reason: Solved
 I finally figured out how to add a localization mechanism for function libraries. In the future, I will use it in all my plugins. |
