2 Pages<12
Offline uni
#21 Posted : 20 December 2021 22:11:14(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Edited by user 20 December 2021 22:15:22(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline uni
#22 Posted : 24 December 2021 12:00:02(UTC)
uni
Updated.
Changes:
- updated to GSL 2.7;
- gsl_version operand added;
- refactored.
Russia ☭ forever
Offline uni
#23 Posted : 24 December 2021 17:13:05(UTC)
uni
Updated.
Changes:
- gsl_sf() function added (only airy supported);
- totally refactored.
The library has a huge number of functions, but it is very difficult to find a convenient method for calling them. I decided to try one method, calling special functions with one generic function and a combination of flags.
Click to enlarge
Edited by user 25 December 2021 00:27:51(UTC)  | Reason: Not specified
Russia ☭ forever
on 24/12/2021(UTC)
Offline uni
#24 Posted : 25 December 2021 00:28:46(UTC)
uni
SMath Studio compatibility Examples
Updated.
Changes:
- gsl_sf_airy() and gsl_sf_bessel() functions added;
- gsl_sf() function removed;
- examples added;
- refactored.
Click to enlarge Click to enlarge
Links:
1. Airy Functions and Derivatives
2. Bessel Functions
Edited by user 25 December 2021 00:37:47(UTC)  | Reason: Not specified
Russia ☭ forever
Offline DenisArd
#25 Posted : 01 February 2022 15:27:54(UTC)
DenisArd
Плагин установлен и виден в SMath, но ни одна его функция не доступна. В чем может быть дело?
The plugin is installed and visible in SMath, but none of its functions are available. What can be wrong?
Windows 10 Home x64 21H1, SMathStudioDesktop portable (mono).
Upd: Разобрался. Нужен Microsoft Visual C++ 2015 Redistributable.
Understood. Requires Microsoft Visual C++ 2015 Redistributable.
https://www.microsoft.co...ad/details.aspx?id=53840
Edited by user 01 February 2022 16:19:59(UTC)  | Reason: Solved
Offline uni
#26 Posted : 03 June 2022 21:51:43(UTC)
uni
SMath Studio compatibility gsl_interp.cpp
Updated.
Changes:
- gsl_interp() function added.
Click to enlarge
gsl_interp.sm (9kb) downloaded 25 time(s).
Links:
1. GSL Interpolation.
Edited by user 04 June 2022 09:15:40(UTC)  | Reason: Not specified
Russia ☭ forever
on 04/06/2022(UTC)
Offline uni
#27 Posted : 05 June 2022 19:32:31(UTC)
uni
Resources
I finally figured out how to add a localization mechanism for function libraries. In the future, I will use it in all my plugins.
Russia ☭ forever
on 06/06/2022(UTC)
Offline uni
#28 Posted : 10 March 2023 16:27:36(UTC)
uni
Updated.
Changes:
- gsl_sf_erf(1), gsl_sf_erfc(1), gsl_sf_erf_Q(1), gsl_sf_erf_Z(1), gsl_sf_hazard(1) and gsl_sf_log_erfc(1) functions added.
Russia ☭ forever
on 10/03/2023(UTC),  on 14/03/2023(UTC)
Offline Razonar
#29 Posted : 03 March 2024 20:18:11(UTC)
Razonar
Uruguay
Hi Viacheslav. It looks like a bug.
Offline uni
#30 Posted : 04 March 2024 20:24:55(UTC)
uni
As for the last error, this is by design. Function expected as first argument.
Click to enlarge
Here my results:
Click to enlarge
The problem may be related to this
Click to enlarge
I don't know exactly which one is used by the plugin. You can try reinstalling the Microsoft Runtime support library.
Russia ☭ forever
Offline uni
#31 Posted : 04 March 2024 23:04:27(UTC)
uni
Updated.
Changes:
- gsl_msc_ver and gsl_msc_full_ver operands added.
Maybe this will help in the future.
Click to enlarge
Links:
1. Microsoft Visual C++ compiler versioning
2. How to Detect if I'm Compiling Code with a particular Visual Studio version?
I do not attach the necessary package with support libraries because I don't know what compiler the project itself is built with. This is done on the build server side and may change from time to time.
All similar plugins have a similar problem.
Edited by user 04 March 2024 23:15:01(UTC)  | Reason: Not specified
Russia ☭ forever
on 05/03/2024(UTC)
Offline Razonar
#32 Posted : 05 March 2024 04:19:45(UTC)
Razonar
Uruguay
Hi Viacheslav. Thanks. I forgot to tell the operating system: Win10 32 bit. I check the 64 bit version and works fine, as you says. The library gsl32.dll seems to need vcruntime140.dll and msvcp140.dll. I see if I can update Microsoft Runtime support library also.
Offline uni
#33 Posted : 05 March 2024 06:54:12(UTC)
uni
There really is a problem with the 32-bit version of the GSL. I can't debug the function because it gives me an error. This may be due to the project settings for building the 32-bit version of the plugin.
P.S. Only some of the functions in the 32-bit version of the library do not work.
Edited by user 06 March 2024 20:31:35(UTC)  | Reason: Not specified
Russia ☭ forever
on 05/03/2024(UTC)
2 Pages<12
