SMath Studio Forum
Questions
error when creating a matrix from a function
Joined: 28/05/2020(UTC) Posts: 18 Location: Bartlesville, OK Was thanked: 4 time(s) in 2 post(s)
I have a function called "rfun(x,y) that calculates a dimensionless reaction rate. The function works fine when calculating a single value, but when it appears in a program function used to create a matrix of rates for x and y vector inputs, it doesn't work properly. All elements of the resulting matrix contain the same value which corresponds to the last value calculated. See below. I found a workaround as shown in the next image. All of the elements produced by these two functions are correct. Can anyone explain why the first method doesn't work? If I try this method with simpler functions, it works fine. The rfun function involves some use of the Prode Physical properties which may be a cause. However, since the rfun function works fine for a single result, I don't understand why it doesn't work here. Also, the rfun function doesn't work in Maxima Draw3d either. Also, is there a more elegant workaround that could be done in just one program function?
No document = No monkey see no monkey do
I found a solution. When I create the rfun function, I do it with a program. The first line of the program is a Clear() statement that clears the output of the rate function. The second line is the result = math expression, and the last line is the result variable for the output.
I had previously tried using clear statements in the matrix creation function with no success.
Originally Posted by: Harvey Hensley I had previously tried using clear statements in the matrix creation function with no success. When re-using matrix/vector in program, set [M, V]:=0
SMath Studio Forum
Questions
