Offline Harvey Hensley
#1 Posted : 04 July 2020 00:18:32(UTC)
Harvey Hensley
Rank: Member
Was thanked: 4 time(s) in 2 post(s)
I have a function called "rfun(x,y) that calculates a dimensionless reaction rate. The function works fine when calculating a single
value, but when it appears in a program function used to create a matrix of rates for x and y vector inputs, it doesn't work properly.
All elements of the resulting matrix contain the same value which corresponds to the last value calculated. See below.
result using rfun directly
I found a workaround as shown in the next image. All of the elements produced by these two functions are correct.
the workaround
Can anyone explain why the first method doesn't work? If I try this method with simpler functions, it works fine. The rfun function involves some use of the Prode Physical properties which may be a cause. However, since the rfun function works fine for a single result, I don't understand why it doesn't work here. Also, the rfun function doesn't work in Maxima Draw3d either.
Also, is there a more elegant workaround that could be done in just one program function?
#2 Posted : 04 July 2020 02:25:23(UTC)
No document = No monkey see no monkey do
#3 Posted : 04 July 2020 03:25:43(UTC)
Harvey Hensley
Rank: Member
I found a solution. When I create the rfun function, I do it with a program. The first line of the program is a Clear() statement that clears the output of the rate function. The second line is the result = math expression, and the last line is the result variable for the output.
I had previously tried using clear statements in the matrix creation function with no success.
#4 Posted : 04 July 2020 14:22:25(UTC)
When re-using matrix/vector in program, set [M, V]:=0
on 05/07/2020(UTC)
