Offline Ale16595
#1 Posted : 05 November 2019 20:02:37(UTC)
Ale16595
Hi to everyone
I am having difficulty solving a linear system like in the picture.
the error says:"impossible to get or set an item because it does not exist"
does anyone know where the error can be and how to solve this problem?
Thanks in advance
Offline PompelmoTell
#2 Posted : 05 November 2019 21:08:12(UTC)
PompelmoTell
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
Offline Ale16595
#3 Posted : 05 November 2019 21:52:23(UTC)
Ale16595
I tried another function but it still gives me an error...
#4 Posted : 06 November 2019 05:57:28(UTC)
It's a huge system, and generally does not accept all initials same.
I would zap units first. This kind of solving should have it be
solved from P & P [Pain & Prestige] as it reflects real project
that does come out of the blue. Even Mathcad Given/Find may fail
or pedal through constrain.
Attach the work sheet ... some source reference as well.
Offline Ale16595
#5 Posted : 06 November 2019 08:25:20(UTC)
Ale16595
here is the spreadsheet
calcoli.sm (47kb) downloaded 19 time(s).
it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
Offline mkraska
#6 Posted : 06 November 2019 10:16:32(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
Equations 3 and 4 probably demand different values for N.r+N.f So there is no solution.
If the system has a solution, the function Solve() from Maxima plugin might find it.
on 06/11/2019(UTC)
#7 Posted : 06 November 2019 21:20:34(UTC)
1. equalities [1,2,3] are consistant 'N'
2. equalities [4,5,6] are inconsistant 'mixed units'
calcoli.sm (53kb) downloaded 17 time(s).
You must make the system consitant before attempting solve.
Offline Ale16595
#8 Posted : 06 November 2019 21:35:50(UTC)
Ale16595
I tried to use the solve function but it still gives me an error saying that S is not defined
#9 Posted : 06 November 2019 21:47:31(UTC)
Did you read my reply just before your visit ?
Offline Ale16595
#10 Posted : 06 November 2019 22:20:21(UTC)
Ale16595
sorry, when I wrote, I didn't notice your message
Offline Razonar
#11 Posted : 11 November 2019 05:11:18(UTC)
Razonar
Uruguay
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
calcoli.sm (51kb) downloaded 21 time(s).
Offline Ale16595
#12 Posted : 11 November 2019 13:37:20(UTC)
Ale16595
Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution.
I will have to modify the whole problem.
#13 Posted : 11 November 2019 20:55:47(UTC)
Hello Alvaro,
The attached CSTR [SS 6179] example is offered differently,
it is initialized from random guesses: success.
Solve al_nleqsolve CSTR.sm (39kb) downloaded 32 time(s).
on 12/11/2019(UTC)
Offline Razonar
#14 Posted : 12 November 2019 19:29:59(UTC)
Razonar
Uruguay
Hello Alvaro,
Hi Jean. Thanks, very interesting.
