SMath Studio Forum
Questions
error in a system of equations
Hi to everyone I am having difficulty solving a linear system like in the picture. the error says:"impossible to get or set an item because it does not exist" does anyone know where the error can be and how to solve this problem? Thanks in advance
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
I tried another function but it still gives me an error...
Originally Posted by: Ale16595 I tried another function but it still gives me an error... It's a huge system, and generally does not accept all initials same. I would zap units first. This kind of solving should have it be solved from P & P [Pain & Prestige] as it reflects real project that does come out of the blue. Even Mathcad Given/Find may fail or pedal through constrain. Attach the work sheet ... some source reference as well.
here is the spreadsheet calcoli.sm (47kb) downloaded 19 time(s).it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
Equations 3 and 4 probably demand different values for N.r+N.f So there is no solution. If the system has a solution, the function Solve() from Maxima plugin might find it. |
Originally Posted by: Ale16595 here is the spreadsheet 1. equalities [1,2,3] are consistant 'N' 2. equalities [4,5,6] are inconsistant 'mixed units' calcoli.sm (53kb) downloaded 17 time(s).You must make the system consitant before attempting solve.
I tried to use the solve function but it still gives me an error saying that S is not defined
Originally Posted by: Ale16595 I tried to use the solve function but it still gives me an error saying that S is not defined Did you read my reply just before your visit ?
Originally Posted by: Jean Giraud Originally Posted by: Ale16595 I tried to use the solve function but it still gives me an error saying that S is not defined Did you read my reply just before your visit ? sorry, when I wrote, I didn't notice your message
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results) calcoli.sm (51kb) downloaded 21 time(s).Best regards. Alvaro.
Originally Posted by: Razonar Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results) calcoli.sm (51kb) downloaded 21 time(s).Best regards. Alvaro. Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution. I will have to modify the whole problem.
Hello Alvaro, The attached CSTR [SS 6179] example is offered differently, it is initialized from random guesses: success. Cheers ... Jean Solve al_nleqsolve CSTR.sm (39kb) downloaded 32 time(s).
Originally Posted by: Jean Giraud Originally Posted by: Razonar Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
Hello Alvaro, The attached CSTR [SS 6179] example is offered differently, it is initialized from random guesses: success. Cheers ... Jean Solve al_nleqsolve CSTR.sm (39kb) downloaded 32 time(s). Hi Jean. Thanks, very interesting. Best regards. Alvaro.
SMath Studio Forum
Questions
