2 Pages<12
#21 Posted : 16 September 2019 19:18:34(UTC)
Was thanked: 753 time(s) in 594 post(s)
... I like this earth-ground-field !
Image Gaussian Spot [red_blue Sattelites].sm (30kb) downloaded 5 time(s).
Offline uni
#22 Posted : 16 September 2019 21:38:20(UTC)
uni
Was thanked: 878 time(s) in 493 post(s)
Originally Posted by: jb_bairoletto Go to Quoted Post
Have a look to this. I am loading the same file in two differente versions of Smath (last version and last beta).
XYPlotRegion updated. Try now.
Russia ☭ forever
Viacheslav N. Mezentsev
💰 Support me for plugins development: https://money.yandex.ru/to/410013245578758/100
on 16/09/2019(UTC)
#23 Posted : 16 September 2019 22:33:58(UTC)
... updated wrt sattelites
2D Util Points Grid_Lines Canvas ADVANCED [Part7] IEEE-80.sm (295kb) downloaded 5 time(s).
Offline jb_bairoletto
#24 Posted : 16 September 2019 23:03:00(UTC)
jb_bairoletto
Rank: Member
Argentina
Hi!!!
Thank you for the dedicated help!!
I am attaching a real output (from a real calculation).
Another thing is that rods should be placed from outside to inside (first from vertices, second in primeter and the in the interior of the mesh).
I think that could be too complex!
Calculo PAT IEEE-80-2000 R10 dibujo.sm (56kb) downloaded 10 time(s).
#25 Posted : 16 September 2019 23:11:01(UTC)
... from native SS6179
#26 Posted : 17 September 2019 00:39:23(UTC)
second in perimeter and the in the interior of the mesh).
I quite not understand
Attached doctored version.
Calculo PAT IEEE-80-2000 R10 dibujo.sm (54kb) downloaded 6 time(s).
#27 Posted : 17 September 2019 02:18:22(UTC)
jb_bairoletto
Rank: Member
Argentina
Two things...
1) Right, seem to produce an error, but in version 7030, works... (E pur si muove!! hehehe)
2) The way the rods must be placed, is from perimeter to the center of the mesh (not in a random way).
So, the first 4 rods should be places in the 4 vertices of the mesh. The fifth rod must be in middle of a side (any one).
The sixth, in the middle of other side, and so on until complete all the perimeter crosses (or Tees).
After that, the rods must be dran in the inner rectangel (counting from the perimeter to the center of the mes), and in the same way as before, the rods will be completing this internal perimeter.
(I dont know if I make mysel clear... Sad )
#28 Posted : 17 September 2019 02:52:30(UTC)
I don't know if I make myself clear
In some way yes, but looks involved.
IEEE-80 is over-killed by protection dogs from pissing on the fence.
What about two bison fighting for MaMa ?
Or deer jumping 10 ft high fence ... more ?
Fence.sm (24kb) downloaded 5 time(s).
#29 Posted : 17 September 2019 03:54:40(UTC)
IEEE-80 shows metallic main ground conductor.
What about termites ?
In their French colonial Africa, they soon learned
metallic installations lasted few moons, only.
Maybe , there are ways to automate the demo.
Fence.sm (30kb) downloaded 5 time(s).
#30 Posted : 17 September 2019 05:03:44(UTC)
... you can have as many sub-squares as you wish, manually.
The interlacing to show the grid lines to center,
they are purely figurative/implicit, not really needed.
Only one set of interlace is needed, not offered.
Fence.sm (46kb) downloaded 4 time(s).
#31 Posted : 17 September 2019 05:37:57(UTC)
... radial rod lines added ... pretty messy !
Fence.sm (55kb) downloaded 4 time(s).
#32 Posted : 17 September 2019 05:45:28(UTC)
... all radial added.
Fence.sm (55kb) downloaded 9 time(s).
#33 Posted : 17 September 2019 13:43:50(UTC)
... multiple scaled perimeters c/w radial grids.
Fence_Radial.sm (16kb) downloaded 7 time(s).
#34 Posted : 17 September 2019 15:02:39(UTC)
Try this [2n] for a beautiful 4 branches star.
Fence_Radial.sm (18kb) downloaded 4 time(s).
#35 Posted : 17 September 2019 23:09:57(UTC)
... random added on outer fence.
You can have random for more/all inner fences.
You may have to strip for multiplicate(s) random.
Anything useful in there ?
Previous attachment deleted, Strip(,) was not correct.
Fence_Radial.sm (35kb) downloaded 7 time(s).
#36 Posted : 18 September 2019 17:55:06(UTC)
After that, the rods must be drawn in the inner rectangle (counting from the perimeter to the center of the mes), and in the same way as before, the rods will be completing this internal perimeter.
No problem for sequence square construct ... more work rectangle.
I guess that concerns the physical steps in-situ [construction crew].
Once physical installation is complete ... same plotting canvas.
Maybe, I understand not enough in there.
The sequence demo may be automated.
Please read the two attachments.
Project Square Radial Canvas.sm (51kb) downloaded 5 time(s).
Project Square Rectangular Canvas [Satellites].sm (299kb) downloaded 5 time(s).
#37 Posted : 18 September 2019 20:42:29(UTC)
jb_bairoletto
Rank: Member
Argentina
To make myself more clear, look a this final 3D approach with 4 rods in vertices. The final plot could be something like that. Crazy
This represent a mesh of "conductors/buried cables" (square or rectangular) and 4 rods stuck in the ground.
Right know I am only experimenting ploting in 2D, with cables (represented as vectors) and rods (represented as points).
#38 Posted : 19 September 2019 03:18:03(UTC)
Right know I am only experimenting plotting in 2D, with cables (represented as vectors) and rods (represented as points).
You can have the grid bed as 3D plotted as 2D,
c/w 4 degrees of rotation. But can't have legs.
Your CAD drawing is pure visual, has nothing to do
with the maths suite wrt IEEE-80
Smath is an advanced CAS ... not at all a CAD.
Finish the CAD drawing, capture as an image, paste in Smath document.
Once rotated, it may be possible to add legs in the attached.
Project Square Rectangular Canvas [Rotate Fied].sm (31kb) downloaded 7 time(s).
#39 Posted : 19 September 2019 18:35:43(UTC)
... 4 legs added to the picnic table.
Can be rotated in 5 degrees of rotation.
Project Square Rectangular Canvas [Rotate Field].sm (49kb) downloaded 9 time(s).
2 Pages<12
