I get the following error: "Matrix must be square" when taking the SQRT of a single column Matrix. Is there some way to do this calculation? PKlijn attached the following image(s):
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
One of the ways File Attachment(s): Ek.sm (5kb) downloaded 19 time(s). Ber7 attached the following image(s):
You may consider using lists (AKA "systems" ). If the input values are obtained as matrix, then the function sys2mat from the CustomFunctions Plugin may help. File Attachment(s): mkraska attached the following image(s): |
