Offline Kasperhaack
#1 Posted : 06 December 2012 15:28:27(UTC)
Kasperhaack
Denmark
Im working with trigonometry, how do I get the cos and sin functions to return the result i degrees?
#2 Posted : 06 December 2012 16:24:29(UTC)
Hi Kasperhaack Offline Good
To show or to customize an output unit you must type the apostrophe on the placeholder in the right side of the equation, and then you can type the unit ° or you can choose one from the list that appear (the dynamic assistance box).
EDIT: see also UNITS ON WIKI
regards,
w3b5urf3r
Edited by user 02 January 2013 23:42:49(UTC)  | Reason: Not specified
Offline oscampo
#3 Posted : 06 December 2012 18:11:00(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Kasperhaack,
In the same way you can use degrees inside trigonometric functions:
cos(45° )=0.7071
Oscar
Offline Kasperhaack
#4 Posted : 10 December 2012 13:58:30(UTC)
Kasperhaack
Denmark
Thank you guys!
Offline PompelmoTell
#5 Posted : 08 May 2013 13:29:38(UTC)
PompelmoTell
looks like they're back problems with degrees in 0.96.4875 version.
such as "cos (45°Wink" does not work in numeric mode
#6 Posted : 08 May 2013 13:57:58(UTC)
works for me (win7 x64)
#7 Posted : 08 May 2013 14:11:47(UTC)
PompelmoTell
from me no :'(
win7 64
Offline omorr
#8 Posted : 08 May 2013 15:05:51(UTC)
omorr
Serbia
It works for me as well
Win7 - 64
#9 Posted : 08 May 2013 15:38:00(UTC)
from me no :'(
win7 64
Qual'è il messaggio di errore? Puoi postare questo file?
What's the error message? Can you share this file?
Offline oscampo
#10 Posted : 08 May 2013 16:28:25(UTC)
oscampo
Colombia
from me no :'(
win7 64
Hi Sergio, what is the error message from SMath in the "cos(45° )= " in numeric mode?
Oscar
#11 Posted : 08 May 2013 17:13:56(UTC)
PompelmoTell
The PC reboots everything works correctly
I remember that the problem occurred after testing Radovan files with two files that interfere "No_units_used.sm" and "Units_dont_mathc.sm"
I think it's related to that problem but I did not understand in what way.
As written by Ioan there may be a problem internal memory management to Smath
Per Davide (se ciò che ho scritto sopra è gravemente scorretto per favore correggimi)
Al riavvio del PC tutto funziona correttamente.
Ricordo che il problema è avvenuto dopo aver testato i file di Radovan con i due files che interferiscono "No_units_used.sm" and "Units_dont_mathc.sm"
Credo che sia legato a quel problema ma non ho capito in quale maniera. Come scrive Ioan potrebbe esserci un problema di gestione della memoria interno a Smath
#12 Posted : 08 May 2013 17:36:47(UTC)
Ok, I understand; this permeability is not good Shok . However remember that SMath Studio 0.96.4875 is a "nightly build" (a beta, in practice Beta ) so could cause some issues....
Ok ho capito, queste interferenze tra files non mi sembrano una buona cosa. Comunque ricorda che l'ultima versione è una "nightly build" (una beta, fra l'altro è stata postata solo nella sezione inglese del forum e in una sotto-sezione a parte) quindi è facile che contenga errori.
best regards,
w3b5urf3r
Edited by user 08 May 2013 18:16:28(UTC)  | Reason: Not specified
on 08/05/2013(UTC)
