Im working with trigonometry, how do I get the cos and sin functions to return the result i degrees?
Originally Posted by: Kasperhaack Im working with trigonometry, how do I get the cos and sin functions to return the result i degrees? Hi
Kasperhaack
To show or to customize an output unit you must type the apostrophe on the placeholder in the right side of the equation, and then you can type the unit ° or you can choose one from the list that appear (the dynamic assistance box). EDIT: see also UNITS ON WIKIregards, w3b5urf3r Edited by user 02 January 2013 23:42:49(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Kasperhaack, In the same way you can use degrees inside trigonometric functions:
cos(45° )=0.7071
Oscar
Hello, looks like they're back problems with degrees in 0.96.4875 version. such as "cos (45° " does not work in numeric mode sergio
Originally Posted by: PompelmoTell Hello, looks like they're back problems with degrees in 0.96.4875 version. such as "cos (45° " does not work in numeric mode sergio works for me (win7 x64) Davide Carpi attached the following image(s): |
from me no :'( win7 64 sergio
It works for me as well Win7 - 64 Regards, Radovan omorr attached the following image(s): |
Originally Posted by: PompelmoTell from me no :'( win7 64 sergio Qual'è il messaggio di errore? Puoi postare questo file?
What's the error message? Can you share this file? |
Originally Posted by: PompelmoTell from me no :'( win7 64 sergio Hi Sergio, what is the error message from SMath in the "cos(45° )= " in numeric mode? Regards, Oscar
The PC reboots everything works correctly I remember that the problem occurred after testing Radovan files with two files that interfere "No_units_used.sm" and "Units_dont_mathc.sm" I think it's related to that problem but I did not understand in what way. As written by Ioan there may be a problem internal memory management to Smath
Per Davide (se ciò che ho scritto sopra è gravemente scorretto per favore correggimi) Al riavvio del PC tutto funziona correttamente. Ricordo che il problema è avvenuto dopo aver testato i file di Radovan con i due files che interferiscono "No_units_used.sm" and "Units_dont_mathc.sm" Credo che sia legato a quel problema ma non ho capito in quale maniera. Come scrive Ioan potrebbe esserci un problema di gestione della memoria interno a Smath
Per Davide (se ciò che ho scritto sopra è gravemente scorretto per favore correggimi) Al riavvio del PC tutto funziona correttamente. Ricordo che il problema è avvenuto dopo aver testato i file di Radovan con i due files che interferiscono "No_units_used.sm" and "Units_dont_mathc.sm" Credo che sia legato a quel problema ma non ho capito in quale maniera. Come scrive Ioan potrebbe esserci un problema di gestione della memoria interno a Smath Ok, I understand; this permeability is not good . However remember that SMath Studio 0.96.4875 is a "nightly build" (a beta, in practice ) so could cause some issues.... --- Ok ho capito, queste interferenze tra files non mi sembrano una buona cosa. Comunque ricorda che l'ultima versione è una "nightly build" (una beta, fra l'altro è stata postata solo nella sezione inglese del forum e in una sotto-sezione a parte) quindi è facile che contenga errori. best regards, w3b5urf3r Edited by user 08 May 2013 18:16:28(UTC)
