I moved a few files into the snippet directory. When I try to import them they do not show up on the list. I tried restart. I also noticed they are missing when I try to manually open them using File-Open.
Joined: 10/12/2009(UTC) Posts: 247 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Hi, Some short answres could help... Which version of SMath are you using? If you are working on windows Vista/7 platform, have you administrator privileges?
Oscar
Latest version of SMath on WinXP.
Did you try to set snippet Shortcut using "File" > "Properties"? Andrey Ivashov attached the following image(s):
I figured it out, I had to open the file and then save it in the snippets directory. A drag and drop does not work. Thanks for the help. Edited by moderator 17 June 2012 12:44:01(UTC)
| Reason: Not specified
