Offline Ward
#1 Posted : 12 June 2012 16:57:52(UTC)
Ward
I moved a few files into the snippet directory. When I try to import them they do not show up on the list. I tried restart. I also noticed they are missing when I try to manually open them using File-Open.
Offline oscampo
#2 Posted : 12 June 2012 17:53:38(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Some short answres could help...
Which version of SMath are you using? If you are working on windows Vista/7 platform, have you administrator privileges?
Oscar
Offline Ward
#3 Posted : 12 June 2012 20:07:27(UTC)
Ward
Latest version of SMath on WinXP.
Offline Andrey Ivashov
#4 Posted : 12 June 2012 21:05:56(UTC)
Did you try to set snippet Shortcut using "File" > "Properties"?
Andrey Ivashov attached the following image(s):
Offline Ward
#5 Posted : 12 June 2012 22:51:38(UTC)
Ward
I figured it out, I had to open the file and then save it in the snippets directory. A drag and drop does not work. Thanks for the help.
Edited by moderator 17 June 2012 12:44:01(UTC)  | Reason: Not specified
