Offline Andrey Ivashov
#1 Posted : 20 May 2012 21:06:16(UTC)
Was thanked: 2012 time(s) in 680 post(s)
New SMath Studio 0.94.4523 Stable available
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
SMath Studio Desktop on the Desktop (Windows)
SMath Studio Desktop on the Desktop (Linux)
Last changes
  • Picture Region improved to support scaling and read-only mode;
  • Picture Region improved to be automatically fitted to the page width on Picture insert if page layout specified;
  • Added support for colors specifying for the special objects and strings into the Plot Region using web format (like #6699CC);
  • Function sum(1) now built-in to the program;
  • Continue and Break statements implemented.
  • Area Region improved to support multi-language feature for the Area titles;
  • Added ability to set title for the Separator Region;
  • Descriptions can be now used not only for Math Regions but for any evaluable regions like Plot Region;
  • Pound-mole (lbmol) built-in Unit added;
  • Added ability to start SMath Studio in silent mode using '-silent' argument next to the list of worksheet files to process files without starting SMath Studio GUI;
  • Handling of arguments separator keying improved in Math Region;
  • Added ability to add a new cell to the vector/system/line by keying arguments separator;
  • Error handling corrected to indicate whether it is not possible to define element of the nested arrays using el(..) function;
  • Unit conversion corrected when working with operations like (1/a)^b -> 1/a^b;
  • Default Text Region font name now don't exported to .sm/.smz file saving;
  • Several critical/calculation issues fixed usually appeared on complex units evaluation;
  • Fixed issues when Description of the evaluable region become empty after file save/load cycle.
  • Fixed issue when undesirable brackets appeared sometimes around the pasted math expressions;
  • Fixed critical error of Text Region appeared sometime on Cut/Backspace operations;
  • Fixed error tooltip location issue when Region for the tooltip located between two Collapsed Areas;
  • Fixed issue when Separator cannot be moved by the mouse;
  • Fixed error appeared in some cases when big numbers processed with symbolic engine ("xE" error);
  • Fixed error appears for min/max functions when working with zeros and other values that includes units;
  • Fixed issue when it was impossible to use trailing zeros option for zero results;
  • Fixed issue when some functions are shown twice in the Insert Function dialog;
  • Fixed critical error appeared on removing of empty cell from the vector/system/line functions if nested matrix/system/line exists there;
  • Critical error appears on Region remove if the Region focused and located after the collapsed Area fixed;
  • Fixed Region's selection error appeared sometime on fast mouse clicks;
  • Fixed new Region painting issue if a Region added to the top left corner of the Worksheet;
  • Fixed error of defining matrix elements using symbolic optimization;
  • Fixed critical error appears on evaluation if manually assigned result Units contains any math error;
  • Fixed simplification errors of the boolean operators related to wrong sign of the result expression;
  • Fixed errors of the operations with matrices and scalars in symbolic library;
  • Examples improved;
  • Refactoring.
Changes since SMath Studio 0.94
  • Critical error fixed appeared on changing Description language of the set of evaluable Regions when one or more Regions in the set has no Description at all;
  • Calculation errors fixed in symbolic library for the following expressions: sin(atan(x)), cos(acot(x)), tan(asin(x)), tan(acos(x)), cot(asin(x)) and cot(acos(x));
  • Working with multi-language enabled Text Regions improved;
  • Resizing of the Picture fixed;
  • Critical error appears on operator keying fixed;
  • Product function button on the right panel fixed;
  • Sum function button on the right panel repaired to insert sum(4).
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop and Handheld (34 languages):
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrain / Українська
    Free Download
    Note: No current version of SMath Studio Handheld release will be introduced. Please use the latest stable handheld version (0.90).
    Tutorial
    • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
    Other files
    SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
  • thanks 4 users thanked Andrey Ivashov for this useful post.
    on 21/05/2012(UTC),  on 21/05/2012(UTC),  on 21/05/2012(UTC),  on 22/05/2012(UTC)
    Offline Jarrinator
    #2 Posted : 21 May 2012 04:16:46(UTC)
    Jarrinator
    Rank: Member
    Ecuador
    Was thanked: 7 time(s) in 4 post(s)
    Thanks for fixing the pi product function and for using sum(4) instead of sum(1) in the right-hand side palette.
    Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
    Offline noxx
    #3 Posted : 24 May 2012 12:50:00(UTC)
    noxx
    - unfortunately not possible to delete an imported picture
    + picture scale works fine
    #4 Posted : 24 May 2012 13:29:22(UTC)
    Was thanked: 1405 time(s) in 914 post(s)
    Huh i've not seen your issue... i can delete imported images without problems...
