Offline crun
#1 Posted : 14 May 2018 08:34:06(UTC)
crun
It would really help to have a fast way of entering powers of ten.
In electronics, every number has a large exponent and entering 15 * 10 ^ 7 is harder than 15E7
(8 keystrokes vs 4)
I think that there should be an option to treat the special case of <number>E<number> , as the exponent operator.
* is automatically inserted when going from numbers to letters, but this is no problem.
ie new behaviour: 15E6 -> 15*10^6
old: 15E6 -> 15*E6
Problem: variable names like E or E6FilmMass, would need to have an operator explicitly used, and could not use the current automatic * operator insertion
Alternatives: use ctrl+E or alt+E as simple keystroke macro to insert: *10^
Online Jean Giraud
#2 Posted : 14 May 2018 14:23:08(UTC)
Was thanked: 796 time(s) in 630 post(s)
Features request ... What features request ?
Offline oscampo
#3 Posted : 17 May 2018 18:42:41(UTC)
oscampo
Was thanked: 43 time(s) in 30 post(s)
(8 keystrokes vs 4)
Alternative: Define a function E()
thanks 2 users thanked oscampo for this useful post.
on 17/05/2018(UTC),  on 14/09/2020(UTC)
Offline crun
#4 Posted : 25 August 2020 13:01:07(UTC)
crun
not a bad idea. I could also define all the common positives eg
e3:=1000
and maybe the negatives
n3:=10^-3
it would certainly help with matrices as it is more compact too.
With the snippet manager, quite viable.
I do think it would also be good to consider (optionally) using the common exponent notation for display as it is much more compact in arrays. When an array is full of *10^3 it really blows out the size on the page.
Offline mkraska
#5 Posted : 25 August 2020 13:33:04(UTC)
mkraska
Was thanked: 878 time(s) in 557 post(s)
You can write any multiplier in the unit placeholder of results.
Offline crun
#6 Posted : 25 August 2020 14:05:22(UTC)
crun
True, but only in the very limited number of cases where all elements have the same exponent.
Online Jean Giraud
#7 Posted : 25 August 2020 15:40:39(UTC)
Make your own feature to suit peculiar project.
This notation is native in OriginLab.
Maths e(n).sm (15kb) downloaded 6 time(s).
Online Jean Giraud
#8 Posted : 26 August 2020 00:17:13(UTC)
Show the array creation c/w the blown page size.
No monkey see, no monkey do !
Offline mkraska
#9 Posted : 27 August 2020 17:49:20(UTC)
mkraska
How about the Table region?
sci.sm (14kb) downloaded 4 time(s).
on 28/08/2020(UTC)
Offline crun
#10 Posted : 28 August 2020 08:31:05(UTC)
crun
That's a useful solution. I see that when scientific is selected, however, that it loses the units.
Is the table plugin part of the closed source, or an open source add on that might be fixable?
[is it: https://smath.info:8443/!/#public/view/head/plugins/TableRegion ?]
However, I would just prefer to have numeric formatting work well in the first place.
Edited by user 28 August 2020 08:36:15(UTC)  | Reason: Not specified
Offline mkraska
#11 Posted : 28 August 2020 09:51:11(UTC)
mkraska
The plugin is open source, just like all third-party plugins.
Online Jean Giraud
#12 Posted : 28 August 2020 14:18:28(UTC)
Table region is part of the SS download as old as SS 6179.
Fix what to this superb delivery ?
Online Jean Giraud
#13 Posted : 29 August 2020 16:36:56(UTC)
It does not lose what's not specified.
Table Scientific.sm (21kb) downloaded 11 time(s).
