Offline Gerjan
#1 Posted : 12 April 2012 13:04:41(UTC)
Gerjan
My compliments for SMath, it's a great program!
I've a question about the possibility of solving an iteration equation with SMath.
To calculate a pressure drop of air flow in a part a calculation is set up.
The equation tries to solve the speed.
A lot of different friction factors are involved, all dependent on Reynolds (and therefore speed).
I don't think the calculations itself are very hard, but there will be a lot of variables.
A friend of mine did something similar in Excel with Macros.
Is it possible to solve complex iteration equations in SMath? (and is it easier/better than Excel)
Are there any examples of iteration equations in SMath? (or with the same structure as SMath)
The exact equation is not yet finished.
I'm also a new user in SMath (I've a few hours experience in Mathcad 2001)
Thanks in advance,
Gerjan
Offline omorr
#2 Posted : 12 April 2012 16:58:20(UTC)
omorr
Serbia
Hello Gerjan,
Try to look in the "Civil Engineering Hydraulics/Fluid Mechanics" under Examples section on SMath Wiki.
Edited by user 12 April 2012 19:21:32(UTC)  | Reason: Not specified
on 13/04/2012(UTC)
Offline Gerjan
#3 Posted : 13 April 2012 11:56:34(UTC)
Gerjan
Thanks for your reply. Didn't see the Wiki page before.
I found this example, and I think it will help me.
I'm happy SMath can do this kind of calculations!
I think further questions will arise as soon as I start with the model.
Thanks for your help so far, I'll keep you guys informed.
Gerjan
Offline Gerjan
#4 Posted : 16 April 2012 17:20:07(UTC)
Gerjan
I want to calculate pressure losses over a part with different friction factors, length and hydraulic diameter.
For each of these factors I want to give a view values.
I've tried to put these values in a matrix but I don't know how to define each variable.
I also put a serie of data in one matrix, but it has to be square...
dp(v)=0,5*rho*[(f*L)/Dh]*v^2
Pressure loss should be calculated first with f1, L1 and Dh1.
And then f2, L2 and Dh2 and so on.
A summation should be done to calculate the total pressure losses.
Can anyone give me tips or an example how to do this?
Offline omorr
#5 Posted : 16 April 2012 19:04:10(UTC)
omorr
Serbia
Hello Gerjan,
file - dp.sm
You should read some tutorials on the Wiki - Tutorials
Offline Gerjan
#6 Posted : 15 May 2012 15:08:51(UTC)
Gerjan
After some practice with help of the tutorials i've completed the calculation.
Thanks for your tips!
I made several smath files. Now i want to summarize these.
Is there an option to collect variables of different files on one sheet?
Offline omorr
#7 Posted : 15 May 2012 21:37:10(UTC)
omorr
Serbia
Hello Gerjan,
Read this file Data files in order to figure out how to exchange data between SMath files.
Read also this post - ImportData. ImportData() function has been implemented and I hope the exportData() will be in the next release.
