  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,589   Was thanked: 1913 time(s) in 652 post(s)
New Beta SMath Studio 0.99.6648 is available!Tiny, but powerful mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. List of changes (between 0.99.6646 and 0.99.6648 versions)Improvements- The following internal setting support implemented: NumbersOutputFormatDisambiguation=CurrentPreset (can be added into settings.inf content as a separate line) - it allows to open legacy files using new numbers format set into program options;
- Support for Shift+Enter keystroke (in addition to Ctrl+Enter) added for equations breaking;
- F11 keystroke handles Step In functionality now;
- Close button added to Debugging/Output panels;
- SS-2322: Ctl+A keystroke enabled into Output window.
Corrections- Vectorization operator improved to support more different cases;
- Select All (or Ctrl+A) inside a Worksheet allowed now when Calculation is in progress;
- Loading of the program became faster on some environment configurations;
- Displayed error occurred on incorrect break/continue usage fixed;
- Rendering of range(..) functions corrected;
- Slow performance of el(..) function in some cases when working with complex numeric expressions fixed;
- Inserting 'i' char after apostrophe symbol or as a first function's name letter fixed;
- SS-3511: Rendering of boolean equal operator improved;
- Result matrix resize symbols made agnostic to fonts available on the machine;
- Symbolic engine error causes evaluation abort fixed;
- Refactoring of the Calculation logic in a separate system thread performed (errors related to manual termination of the evaluation fixed);
- Mouse wheel handling by regions in Pages View mode fixed (it was impossible to use mouse wheel over some parts of the focused region);
- Replacing of function existing on the worksheet with another one using Dynamic Assistance list fixed.
Miscellaneous- Refactoring;
- Errors handling logic reworked;
- Interface translations updated.
Changes introduced in current buildImprovements- The following internal setting support implemented: NumbersOutputFormatDisambiguation=CurrentPreset (can be added into settings.inf content as a separate line) - it allows to open legacy files using new numbers format set into program options.
Corrections- Vectorization operator improved to support more different cases.
Miscellaneous- Critical issue of wrong collapsed area handling on save fixed;
- Refactoring.
Download
on 15/03/2018(UTC), on 15/03/2018(UTC), on 15/03/2018(UTC), on 16/03/2018(UTC), on 16/03/2018(UTC)
This is release candidate. Known observations are fixed. Tests passed OK. No new functionality will be implemented before next Stable release.
Best regards!
 6 users thanked Andrey Ivashov for this useful post.
on 15/03/2018(UTC), on 15/03/2018(UTC), on 15/03/2018(UTC), on 15/03/2018(UTC), on 15/03/2018(UTC), on 16/03/2018(UTC)
Joined: 04/07/2015(UTC) Posts: 6,077  Was thanked: 889 time(s) in 717 post(s)
Originally Posted by: Andrey Ivashov  No new functionality will be implemented before next Stable release. The word is stable release, I will borrow a Win7/10 Will be a big job to test all ! Cheers Andrey ... Jean
