Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,617 Was thanked: 1981 time(s) in 667 post(s)
SMath Studio - SMath
They trust us *
* Customers' names and logos are used with the written permission of the copyright holders.
This is an amazing mathematical tool which is at the same level as some of the most sophisticated and expensive math software. I use it in all my classes and promote its use with all my engineering students.
by Antonio Medrano
Absolutely Gorgeous software, which can be a level riser for spreadsheet calculation, seamlessly extended for any kind of mathematical application.
by Shiju VT
La aparición del proyecto Smath, cubre un vacío que existía en el ámbito del software gratuito para Ingeniería. Es un proyecto que llegó para quedarse, ya que permite logros muy buenos a quienes utilizan esta herramienta. felicitaciones a Andrey y el gran equipo de colaboradores que cada uno con su aporte desinteresado hacen crecer esta aplicación que ya podemos caratular como de uso profesional
by Ing Parcelo Ortiz Plá
Great little tool, happy that someone made this - best alternative for prime. I still hate the breakdown of the Mathcad legacy - you are a proud successor....
by Robbert
Es un programa excelente y muy útil para la enseñanza y aprendizaje en ing. Civil. Muy recomendable!!!
by Wilson Rodríguez Calderón
Amazing, well-done, useful tool. A small donation was sent your way. This small comment of praise is a follow-up.
by Jason H
Smath-Studio is a compelling mathematical application. It allows for quick and efficient symbolic and numerical calculations, making it a better alternative to MathCad, and Mathematica. The developers continue to add new features and functionality to this program regularly. I have been using this application for six months and love it. I tip my hat to the developers, well-done guys!
by Jorge M. Gonzalez PE
Grazie tanto per lo splendido lavoro. Io lo uso per i miei calcoli di elettronica. Большое спасибо за замечательную работу. Я использую его для моих вычислений электроники. Thank you so much for the wonderful job. I use it for my electronics calculations.
by Vito BLASI
Probably the best free math program out there. As an electrical engineer, you can do so many calculations, e.g for designig drive systems and calculate protection settings, can be almost entirely automated using SMath Studio. With the huge amount of plugins you can push SMath in an high level. Thanks a lot!
by Karsten
This is a great tool. Just like Mathcad. I'd encourage science/engineering students to use it. And you get a copy of your work.
by RJ
SMath Studio in publications
The functionality of the program can be expanded through the installation of plug-ins created by third-party developers and companies, as well as those prepared by the SMath LLC team. Most plug-ins are open source and can be modified if necessary.
Extends SMath Studio with a 3D Plot Region.
Jack Xu, Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
Extends SMath Studio with more save/import/export features.
Davide Carpi (davide.carpi@gmail.com)
Access to a set of programs for calculating properties of water, steam, gases and gases mixtures. Requires separate installation of the Water Steam Pro libraries and appropriate license for it (see http://www.wsp.ru/).
ООО "ЭсМат"
Provides access to the free and open source computer algebra system Maxima.
Kay Graubmann & Martin Kraska (THB www.th-brandenburg.de)
Extends SMath Studio with a X-Y Plot Region.
A SMath Studio native wrapper of the CoolProp library (www.coolprop.org) - thermophysical property database and wrappers for a selection of programming environments.
Mike Kaganski
Contains nonlinear solvers for equations and systems of equations: Bisected Direct Quadratic Regula Falsi (BDQRF), Bisection, Brent's, Broyden's, Homotopy, Newton-Raphson, Ridder's, Secant, etc.
Digital Signal Processing Library: spectral analysis, IIR and FIR filters, resampling algorithms, etc.
Sergey Bakhurin (http://dsplib.org), Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
Extends SMath Studio with statistical tools: Sample Estimators, Probability Density, Cumulative Density, Quantile functions, Random Numbers, etc.
Provides an interface to the SQLite relational database engine.
Chris Bietz, Viacheslav N. Mezentsev
on 15/03/2018(UTC), on 15/03/2018(UTC), on 15/03/2018(UTC), on 16/03/2018(UTC), on 16/03/2018(UTC)
