Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Hi, I think that the new (beautiful) feature "show description" should be improved. Actually work in this way: But I think that a vertical offset should be applied/removed to all items below the elements with description visible/hidden best regards w3b5urf3r |
Hello, I hope I understood your comment about "show description" feature. Just imagine that below the particular region is quite an extensive number of regions. Should all the regions be moved up/down? I see this show/hide description in the way that you can have on the screen the description of the particular region instead of the additional text region. This way you can move the region including its description. I think that any kind of moving regions, like in your suggestion, will very likely overlap some regions and it would not be an easy task. At the moment, in the sight of your suggestion - I think that the more desirable feature will be to have some kind of "Separate regions" when the regions overlapped. I do not think it would be any easier. Hope I am right about all of this. Regards, Radovan Edited by user 06 March 2012 17:06:28(UTC)
hello, yes, you're right My first idea was to see something like an Area (when you collapse or expand an area, all the items below are translated by the area height), but the "Separate regions" it's also an excellent idea (but I don't know what is the most expensive in terms of "performance"/"development cost" ratio ) regards w3b5urf3r |
