10 Pages«<45678>»
Offline kilele
#101 Posted : 03 May 2013 00:31:53(UTC)
kilele
I've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error.
Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux.
edit:
yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on.
Edited by user 03 May 2013 00:34:00(UTC)  | Reason: Not specified
#102 Posted : 03 May 2013 00:42:13(UTC)
Hi Radovan Good
The Full Package issue is caused by the ClosedXML library when SMath loads the plugins in the "Plugin" folder (if you put only the ClosedXML.dll file inside the plugin folder of a clean installation the message will appear), the OpenDocument issue by the Ionic.Zip library calling the related functions, I don't know if the 2 bugs are the same or simply similar...
Originally Posted by: omorr Go to Quoted Post
It seems that Martin did not have this problem Wonder
I don't know...
An early Post probably related: Issue SMATH Error - Won't Load Existing XMCD File (Build 0.96.4868) - XMCD File created by previous version will not open in new version
Offline omorr
#103 Posted : 03 May 2013 00:59:06(UTC)
omorr
Serbia
edit:
I tried it as well in Xubuntu using Martins' version. No errors about Ionic.zip. Save as ODT is working, but it seems that only the text can be saved. I did not manage to save formulas and plots.
Offline mkraska
#104 Posted : 03 May 2013 01:11:51(UTC)
mkraska
Was thanked: 1126 time(s) in 723 post(s)
I had a closer look at the DataExchange plugin under 0.96. For now, I see the XeTeX and csv export working fine, others still have to be checked, but there are problems in the example files. Unfortunately, I am not keeping pace with the flood of updates in the forum, thus it will take a while until distro and handbook will have settled and updated. Currently, I am just focussing on bug reports and test feedback.
Offline omorr
#105 Posted : 03 May 2013 01:24:56(UTC)
omorr
Serbia
Hello Davide,
I do not know why some of your post have to be approved sometimes Unsure
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
Hi Radovan Good
I don't know...
Sorry, I forgot that ClosedXML thing Wallbash . Martin mentioned it few times.
Offline kilele
#106 Posted : 03 May 2013 10:28:59(UTC)
kilele
Please download this file to see my test on SolusOS Linux,
Repository: Debian Stable; Desktop manager: Gnome2.3, btw SMath is very responsive in this manager.
This file contains the plugin docs and some screenshots showing errors while running the program.
An this is the plugin tested in Zorin(ubuntu)
http://www.mediafire.com/?p4ehqsr6pgs2vwl
Edited by user 03 May 2013 11:28:34(UTC)  | Reason: Not specified
on 03/05/2013(UTC)
Offline omorr
#107 Posted : 03 May 2013 21:43:29(UTC)
omorr
Serbia
Hi Radovan Good
I don't know...
Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it.
By the way, the activity on the Forum increased quite a lot, almost hard to follow Shok . I am not complaining, just contrary Good
on 03/05/2013(UTC)
Offline uni
#108 Posted : 03 May 2013 21:54:15(UTC)
uni
If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody Secret ):
Edited by user 03 May 2013 21:58:09(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 06/05/2013(UTC)
Offline omorr
#109 Posted : 03 May 2013 22:25:34(UTC)
omorr
Serbia
No Sad Unsure Umnik
#110 Posted : 04 May 2013 00:56:30(UTC)
Thank you uni, this workaround solve all the issues Good
BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required.
best regards,
w3b5urf3r
Offline omorr
#111 Posted : 04 May 2013 01:15:42(UTC)
omorr
Serbia
It does not work for me, or I did not figure out Sad . Never mind, I hope that will work for most of the users Good
#112 Posted : 08 May 2013 02:29:57(UTC)
PLUGIN UPDATED
- change of requirements: SMath Studio 0.96.4875 (07 May 2012)
- relative path improvements;
- ODS export vs symbolic optimization fix;
- patch on ODT embedded images for Linux users;
- SMath Viewer compatible.
best regards,
w3b5urf3r
Edited by user 08 May 2013 02:45:05(UTC)  | Reason: Not specified
on 08/05/2013(UTC)
Offline steveswin
#113 Posted : 08 May 2013 08:12:28(UTC)
steveswin
Rank: Member
Was thanked: 2 time(s) in 1 post(s)
Thanks. Seems to work fine now.
Steve
#114 Posted : 08 May 2013 12:41:30(UTC)
Steve
You're welcome Biggrin
#115 Posted : 10 June 2013 10:41:09(UTC)
PLUGIN UPDATED
- XLSX features moved away (see Xlsx Import/Export plugin )
- plugin added to the Gallery (Latest Nigthly build)
- Added Guid (after installing the plugin, a message should appear opening old files, just skip it and save again the file)
best regards,
Davide
Edited by user 10 June 2013 11:44:23(UTC)  | Reason: Not specified
thanks 4 users thanked Davide Carpi for this useful post.
on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC)
#116 Posted : 17 September 2013 20:10:04(UTC)
UPDATED (Gallery only)
- fixed: SMath Studio 0.96.4909 (10 June 2013) vs XeLaTeX saves
Edited by user 17 September 2013 20:13:00(UTC)  | Reason: Not specified
Offline paolo1963
#117 Posted : 30 December 2013 14:53:11(UTC)
paolo1963
when the program starts, the following message appears
operating system Win 7
smath versione 096 4868
net framework 4.5.1
Edited by user 30 December 2013 14:58:41(UTC)  | Reason: Not specified
paolo1963 attached the following image(s):
#118 Posted : 30 December 2013 16:47:42(UTC)
Hi Paolo,
I can't reproduce your issue (win7 x64 - SMath 0.96.4909) Sad
Are you sure that this plugin cause the issue? copy and paste the red string ( %APPDATA%\smath\extensions\plugins ) in your windows start menu, press the return key and then delete the plugin folder (5dce7298-9e5f-4120-9a2e-49b16daa02a3) then try to start SMath again.
Davide
Edited by user 30 December 2013 17:47:00(UTC)  | Reason: Not specified
Offline paolo1963
#119 Posted : 30 December 2013 22:11:25(UTC)
paolo1963
I uninstalled the version of SMath 096 4868 and I installed version 096 4909 now the program starts.
Save in *. odt work,
while saving in *. tex from the following error message:
#120 Posted : 04 January 2014 03:56:45(UTC)
Really strange, I can't reproduce this issue Crazy
The problem is related to some worksheet (empty file, with figures, with text, with math), some machine, or is general?
Have you the same issues with the unofficial portable version?
You could try to share here your system informations (Development Tools plugin > System informations > save as... > attach here the file) Unsure
Guest (2)
Similar Topics
[Data Exchange Plugin] Export data (more than 4 columns) (Questions)
by chandragon 29/03/2017 12:08:24(UTC)
10 Pages«<45678>»
