Offline uni
#1 Posted : 03 May 2013 14:38:53(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Russia ☭ forever
Viacheslav N. Mezentsev
Offline uni
#2 Posted : 03 May 2013 21:03:45(UTC)
uni
I do not recommend to use this function, because its behavior is not obvious. You can change the current directory of the current process, but it can vary due to external conditions. For example if you save document using Save As option. I did it for myself because I didn't want to write long paths. You can combine her job with a different function from that library. I do not quite understand what exactly needs.
Russia ☭ forever
on 07/05/2013(UTC)
Offline uni
#3 Posted : 03 May 2013 21:27:01(UTC)
uni
Originally Posted by: ioan92 Go to Quoted Post
In fact, my problem is that by using “wfile” and “rfile” functions I am always linked to the APPLICATIONDATA directory.
I would like to force this functions to operate on the CurrentDirectory
Thanks
I think, I can write my own wfile and rfile function, if you really need this. I can add support for file paths.
Something like this?
Russia ☭ forever
on 06/05/2013(UTC)
Offline uni
#4 Posted : 06 May 2013 00:53:25(UTC)
uni
I've added two functions to the MathcadFileAccess plugin: wfile(3) and rfile(2). You can try to use them.
Edited by user 06 May 2013 00:56:29(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/05/2013(UTC)
Offline uni
#5 Posted : 06 May 2013 19:55:33(UTC)
uni
Hi uni,
The two functions work perfect for me.
It seems that they are the same as the standard rfile wfile functions, used in a special (explicite) format ??? or yours functions are replacing purely and simply this funtions conserving only the names ?
However for my practical useit it is what I expected.
Thanks again and Best Regards,
Ioan
They use the same system functions, so you can say that they are doing the same thing. The code size in few lines, so I just wrote them again. You can ask Andrey to add these features to the standard functions.
Russia ☭ forever
on 06/05/2013(UTC)
