10 Pages«<23456>»
Offline mkraska
#61 Posted : 01 February 2013 02:43:47(UTC)
mkraska
Was thanked: 1125 time(s) in 722 post(s)
Sounds great! Looking forward for updated plugin.
Martin
#62 Posted : 02 February 2013 18:55:56(UTC)
PLUGIN UPDATED
- added importData.ODS(2) and importData.XLSX(2)
- changes in ODT/ODF markup (italic greek letters);
- LaTeX format changed to XeLaTeX format (Unicode support);
- changes on XeLaTeX markup + dialog to choose some options;
- Each save dialog can memorize settings;
- Plugin Languages: ENG/ITA/RUS.
best regards,
w3b5urf3r
Edited by user 02 February 2013 21:36:04(UTC)  | Reason: added new functions
thanks 3 users thanked Davide Carpi for this useful post.
on 02/02/2013(UTC),  on 03/02/2013(UTC),  on 03/02/2013(UTC)
Offline mkraska
#63 Posted : 03 February 2013 14:07:50(UTC)
mkraska
Hello w3bsurf3r,
special thanks for the importData.xxx(2) functions.
Meanwhile I am convinced that you found a generic way to handle special characters issues in Latex. My experience with the exported tex file with Miktex under Windows is:
- you need a very recent version (containing XeLaTeX 0.9998)
- you have to manually install XITS and Libertine (font) packages via Package manager.
Given that, compilation is no problem.
I attached my personal "save as" test file, feel free to use that in the plugin docs.
Definitely a matter of taste: I do not need any title page in exported latex documents. Instead, I would propose to obey the page layout settings (heading/footer) as defined in the main program settings.
The assignment operator symbol options might be useful for odt export as well.
Is there sort of localization file/list of strings for the dialogs that I might edit for german UI?
There are still issues with the file directories.
Given your example files, your design intent seems to be that the default directory for import and export should be the directory where the currently executed/active sm sheet resides. This seems sensible to me, thus I would support this point of view.
However, when starting SMath from program manager and then loading a file, the default import/export directory is not the directory of the sm file, but the system user document directory, in my case "C:\users\Kraska\Documents". This is new, as previous versions used the install dir as default in such situations.
In the settings directory, there is a DataExchange subdir with lots of other possibly random named subdirs. I guess, these were created by various versions of the plugin. Can these be safely removed? If so, I would suggest to use system temp dir for such data.
What is the path/name of the dialog settings file?
Martin
Edited by user 03 February 2013 14:12:19(UTC)  | Reason: Not specified
File Attachment(s):
SaveTest.sm (37kb) downloaded 62 time(s).
#64 Posted : 03 February 2013 21:21:29(UTC)
Hi Martin,
I've thinked about that (even for ODT documents), but I've seen many proposal in the forum about header and footer enhancements; I prefer to wait the next SMath relase to see if something changes or not...
Maybe, it's not easy as in TeX documents...
Yes, and would be a pleasure for me to have also the German translation; I attach here the list, send me back a PM with translated strings.
I know that; using the "save"/"save as..." menus and changing the working directory the C# variables that I know does not changes... Actually I'm not able to fix it; BTW I've found a similar issue using links (like those in SMath Reference Book): a link show you another sheet but the domain still remain the same, so if you save a change in a 2nd document you overwrite the 1st, not the 2nd!!!
It's a bug of the previous relase, actually solved... you can delete any folder whitout losses or damages. The change is in my plans, however as for now I want to keep the settings directory (just for public debugging purposes).
DataExchange.dll.config; about location look here http://stackoverflow.com
best regards,
w3b5urf3r
EDIT: "TRANSLATABLE STRINGS" FILE UPDATED
Edited by user 05 February 2013 19:10:49(UTC)  | Reason: "TRANSLATABLE STRINGS" FILE UPDATED
File Attachment(s):
DataExchange - Translation Sheet.zip (2kb) downloaded 67 time(s).
#65 Posted : 05 February 2013 21:41:06(UTC)
PLUGIN UPDATED
- added German language UI;
- CODE: changed language handling.
EDIT: Nightly updated (German XeLaTeX dialog lacks, sorry for the drawback)
best regards,
w3b5urf3r
Edited by user 06 February 2013 03:08:13(UTC)  | Reason: Not specified
#66 Posted : 11 February 2013 13:49:21(UTC)
PLUGIN UPDATED
- added Spanish language UI;
- fixed Italian and Russian UI issues.
best regards,
w3b5urf3r
Offline DuaneKaufman
#67 Posted : 10 April 2013 22:44:01(UTC)
DuaneKaufman
Hello w3bsurf3r,
First, thanks so much for this plugin!
I noticed one abnormality in using it with worksheets containing English units. SMath wishes to use the symbol 'in' for the English unit 'inch', and LibreOffice does not display equations with this unit correctly (LibreOffice 4.0.2.2 Windows 7):
SMath equation:
H := 20 in
Gets exported into LibreOffice and is formatted like:
H_{"b"}`def`{20 ` nitalic in}
Which displays like:
H_b <def>= 20 <upside-down ?> (pardon the use of ascii text where a picture would be better)
If I enclose the 'in' formula definition in double-quotes
H_{"b"}`def`{20 ` nitalic "in"}
the equation displays correctly.
Thanks,
Duane
#68 Posted : 11 April 2013 00:10:55(UTC)
I Duane,
thank you for reporting this issue; I'll fix it ASAP OK [DONE]
best regards,
w3b5urf3r
Edited by user 20 April 2013 01:35:56(UTC)  | Reason: Not specified
#69 Posted : 19 April 2013 18:03:07(UTC)
PLUGIN UPDATED
- OpenDocument files: fixed issue of inch unit ("in" reserved word);
- OpenDocument files: nitalic applied to hyperbolic a*h() functions;
- OpenDocument files: temporary folders moved in the system TEMP folder;
- OpenDocument files: fixed files creation PATH issues on Linux systems;
- Save dialogs: dialog size issue fixed;
- Paths: improvements in path handling;
- Plugin manual: added KNOWN ISSUES section;
Notes on exportData(#) functions
filename argument accept also the fileneme with a path (relative/absolute)
Notes for Linux users
"Current working directory" on Ubuntu is the home folder ("/home/home/" path)
best regards,
w3b5urf3r
Edited by user 19 April 2013 18:37:28(UTC)  | Reason: Not specified
on 19/04/2013(UTC)
Offline mkraska
#70 Posted : 19 April 2013 23:48:43(UTC)
mkraska
If I use the compact version instead of the full version, then one (of possibly more) effects is that the importData.XLSX function is not available any more.
Can the full version be expected to run under .net 2.0 or mono systems?
This would affect the my inofficial distribution with the plugins included.
Edited by user 20 April 2013 00:09:08(UTC)  | Reason: Not specified
#71 Posted : 20 April 2013 00:10:11(UTC)
Hi Martin,
The "Full Package" (previous named as ".NET Framework 3.5" ) works on Linux too (with Mono 2.0 or later) but SMath crashes when you call XLSX I/O functions (At least on my PC; The issue seems something Mono-incompatible in the DocumentFormat.OpenXml.dll library); this is the cause because only the "Compact Package" have explicitly the Mono requirements.
I suggest you to share only the "Compact Package" to ensure the SMath Studio stability on Unix Systems.
best regards,
w3b5urf3r
Edited by user 20 April 2013 00:26:18(UTC)  | Reason: Not specified
#72 Posted : 20 April 2013 01:31:25(UTC)
You can try to add this version of Plugin to your SMath Studio Portable build Beta
Requirements: .NET Framework 3.5 (Windows) / MONO 2.0 or later (Linux);
Limitations: XLSX I/O functions disabled on non-Microsoft systems;
I don't know what could be the behavior of the Linux build on a Windows system without .NET 3.5 Framework (maybe PompelmoTell can help you to test it) Good
best regards,
w3b5urf3r
Edited by user 20 April 2013 01:46:56(UTC)  | Reason: Not specified
File Attachment(s):
on 20/04/2013(UTC)
Offline mkraska
#73 Posted : 20 April 2013 02:44:26(UTC)
mkraska
So I did. Updated version of the inofficial portable build
Any testing and feedback especially from linux users are welcome.
Handbook updated accordingly.
Offline kilele
#74 Posted : 20 April 2013 04:48:56(UTC)
kilele
I'm sure Omorr will test the plugins in your build soon, he recently posted a screenshot from his Linux installation.
You may want to read my adventures in Linux, see the second edit of this post:
http://en.smath.info/for...hen-saving.aspx#post9090
Puppy's windows installers run in a breeze and are safe to uninstall (I suggest precise 55 under 'older and derivatives' )
Edited by user 20 April 2013 12:40:32(UTC)  | Reason: Not specified
on 21/04/2013(UTC)
Offline omorr
#75 Posted : 21 April 2013 00:31:56(UTC)
omorr
Serbia
It seems that running SMath in Linux and Mono is quite "an adventure", as you said. I am afraid I can not do to much regarding this, just to try it like a curious ordinary user - nothing else. As a w3b5urf3r_reloaded plugins fan Good I tried a bit this unofficial portable build (thanking to mkraska). My files I used to test these plugins worked fine. This time I used Xubuntu and found an additional issue (I think) I did not pay to much attention on before (or it might change something in the meantime regarding Xubuntu updates etc.). I did not noted any crashes, only the problem with nonvisible pictures, but I've noted that SMath file can not be safely saved if there are plots and graphs in it. Here are the errors when we try to save a file which includes plots or pictures (first picture), and then when we try to open that file (second picture)- it seems that it is not valid and corrupted. My experience with Linux up to now is: SMath file can be made in Windows, opened in Linux, worked correctly, but can not be saved in Linux if you have plots or pictures in it. I don't have the slightest idea what does it mean and what happened. Moreover, I think that someone already mentioned this corruption things.
Just for the record, here is the file - it seems it stopped at some moment (/dependences tag)
Code:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio" version="0.95"?>
<regions>
  <settings>
    <calculation>
      <precision>4</precision>
      <exponentialThreshold>5</exponentialThreshold>
      <fractions>decimal</fractions>
    </calculation>
    <pageModel active="true" printAreas="true" simpleEqualsOnly="false">
      <paper id="1" orientation="Portrait" width="850" height="1100" />
      <margins left="39" right="39" top="39" bottom="39" />
      <header alignment="Center" color="#a9a9a9">&amp;[DATE] &amp;[TIME] - &amp;[FILENAME]</header>
      <footer alignment="Center" color="#a9a9a9">&amp;[PAGENUM] / &amp;[COUNT]</footer>
    </pageModel>
    <dependences>
      <assembly name="SMath Studio" version="0.95" guid="a37cba83-b69c-4c71-9992-55ff666763bd" />
      <assembly name="Math Region" version="0.95" guid="02f1ab51-215b-466e-a74d-5d8b1cf85e8d" />
      <assembly name="Plot Region" version="1.7.4594.38" guid="c451c2b5-798b-4f08-b9ec-b90963d1ddaa" />
    </d
Edited by user 21 April 2013 01:03:57(UTC)  | Reason: Not specified
on 21/04/2013(UTC)
Offline mkraska
#76 Posted : 21 April 2013 01:39:02(UTC)
mkraska
Radovan and kilele, thanks for reporting linux experience. I shall include corresponding advice in the handbook.
Radovan, do all the problems also occure if there is no external plugin at all? Can you confirm the stability of the yesterday late night adaptivity patch by Davide? This saved me from maintaining two different distributions. However, half of the zip file size comes from the XLSX I/O feature. The distribution without this feature would fit on a floppy disk (as once Derive did).
Can the CR/LF issue be excluded as source for file compatibility problems?
Martin
Offline kilele
#77 Posted : 21 April 2013 06:21:20(UTC)
kilele
As you can see in the Mono download page, the only official distribution supported by Mono is OpenSuse. Could anyone try Smath on that Linux distro downloading monono as explained in that page ? I tried myself but for now I can only access a laptop with 1gb ram.
The safe and easy way to test different linux distros is creating bootable usb sticks with this application:
http://www.pendrivelinux...installer-easy-as-1-2-3/
There is no need to install anything on hard diskd but just run the live distribution version booting the pc from a pendrive.
Edited by user 22 April 2013 12:42:15(UTC)  | Reason: Not specified
Offline omorr
#78 Posted : 21 April 2013 10:55:35(UTC)
omorr
Serbia
Hello Martin
Radovan, do all the problems also occure if there is no external plugin at all? Can you confirm the stability of the yesterday late night adaptivity patch by Davide? This saved me from maintaining two different distributions. However, half of the zip file size comes from the XLSX I/O feature. The distribution without this feature would fit on a floppy disk (as once Derive did).Martin
The save option regarding plots and pictures has no difference using the official build or compact one you've made. I tried Devide's nonlinear solver functions a bit and I and it works, at least everything I tried.
Regarding DataExcange plugin and compact version there are no crashes.
As I could see, save ODS, and save xeLaTex is working.
Export functions are working, except that I have to put the entire path of the file. If I do not put the path (current directory) then functions reported no errors (1) but I can not find them in the current directory. If I put the entire path then it seems ODS,ODF,CSV export seems to be just fine. It seems that XLSX is not working - it produces error "exportData.XLS(,,,) - function is not defined".
Importing functions are a bit problematic. For ODS there is no success. The file can not be find. If it is in the current directory, it can not be find. If I put the entire path than "Path is empty" error issued. It seems that XLSX is not working either - it produces error "importData.XLS(,,,) - function is not defined".
The same situation is when I put the plugin in the official SMath release.
I tried the recent DataExcange plugin from http://en.smath.info/forum/yaf_postsm9118_DataExchange-plugin.aspx#post9118 that Davide recomended.
As a conclusion of this short test. Save is working, Export is working but thu full path must be used, Import is not working, XSLX I/O is not working
BTW, I am using Xubuntu regular installation - not the Live or Virtualbox one. I could try some other ditros latter.
Can the CR/LF issue be excluded as source for file compatibility problems?Martin
Sorry Martin, I have no idea what does it mean.
Edited by user 21 April 2013 11:07:17(UTC)  | Reason: Not specified
on 23/04/2013(UTC)
#79 Posted : 21 April 2013 12:13:35(UTC)
Hi Radovan,
The current working directory path will be fixed after the next SMath relase; as for now on my Ubuntu it's the home directory. Have you tried to use the "full package" on your Linux distro?
best regards,
w3b5urf3r
Offline omorr
#80 Posted : 21 April 2013 13:31:24(UTC)
omorr
Serbia
Hello Davide Good
yes, I did try the "full packeage" as well. There is no difference regarding the path. I should use the full path and my home directory is "/home/omorr/". I like your comment which includes "the next SMath release" Good . As far as I am concerned, SMath under Mono is not so reliable at the moment regarding the behavior of both "ful" or "condensed" versions (as far as I can figure out). I use it on different distros, and the situation on saving problem appeared recently on my Xubuntu. Therefore, I do not know what is the cause of problems - diferent Linux distros, my actual configuration, something else I am not aware of... There are some other annoying things like when you open few SMath files, maximizing is just unavailable sometimes - some of the files are just windowed and can not be maximized. I hope that this will change to a more stable SMath on Linux and I am looking forward to the next SMath release Good . From my own experience, when the Wine or Mono are included, there is quite a chance that some things will simply not work or have some peculiar behavior sometimes.
Edit: By the way, I think I mentioned this already. This "condensed" version is something I would prefer for my teaching in the first place
Edited by user 21 April 2013 13:53:59(UTC)  | Reason: Not specified
Guest (2)
Similar Topics
[Data Exchange Plugin] Export data (more than 4 columns) (Questions)
by chandragon 29/03/2017 12:08:24(UTC)
10 Pages«<23456>»
