2 Pages12>
Offline OchkovVF
#1 Posted : 12 March 2024 04:27:01(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
See please the attach.
I cannot solve the system of equation by all the alpha values from 0 too 360 deg.
Is there the better solver for this task?
Or the better way for the solution.
Chebyshevs-Foot-Stepping-Machine.sm (180kb) downloaded 12 time(s).
Offline StvMath
#2 Posted : 12 March 2024 06:29:43(UTC)
StvMath
United Kingdom
Was thanked: 24 time(s) in 21 post(s)
Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0).
Chebyshevs-Foot-Stepping-Machine_b.sm (177kb) downloaded 6 time(s).
thanks 1 user thanked StvMath for this useful post.
on 12/03/2024(UTC)
Offline OchkovVF
#3 Posted : 12 March 2024 08:12:27(UTC)
OchkovVF
I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04.
Offline StvMath
#4 Posted : 12 March 2024 09:50:39(UTC)
StvMath
United Kingdom
Because L.04 is the same length as L.03 it does, in fact, implicitly depend on L.04. Check the two files for a few angles and you will see that they give the same results (except that my file works for all angles).
Basically, I've used the fact that (x4 + x3)/2 = x0 and (y4 + y3)/2 = y0.
If L.04 and L.03 are different lengths a weighted average would be used, i.e. (L.03*x4 + L.04*x3)/(L.03 + L.04) = x0 and (L.03*y4 + L.04*y3)/(L.03 + L.04) = y0.
Edited by user 12 March 2024 10:26:25(UTC)  | Reason: Not specified
on 12/03/2024(UTC)
Offline OchkovVF
#5 Posted : 12 March 2024 21:37:09(UTC)
OchkovVF
Thanks!
See? please the attach
Chebyshevs-Foot-Stepping-Machine.sm (179kb) downloaded 2 time(s).
Now I will try to plot the trac of the point 4.
Help me please.
Offline StvMath
#6 Posted : 13 March 2024 01:47:02(UTC)
StvMath
United Kingdom
Thanks!
Help me please.
See attached (but I'll leave you to do any animation!).
Chebyshevs-Foot-Stepping-Machine_c.sm (177kb) downloaded 6 time(s).
on 13/03/2024(UTC)
Offline OchkovVF
#7 Posted : 13 March 2024 04:07:28(UTC)
OchkovVF
Thanks!
See please my little editing
Chebyshevs-Foot-Stepping-Machine-Trace.sm (178kb) downloaded 4 time(s).
One question
See please
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (179kb) downloaded 5 time(s).
and tell me - it is my or SMath bug with the plot?
Offline StvMath
#8 Posted : 13 March 2024 06:19:48(UTC)
StvMath
United Kingdom
Thanks!
One question
See please
?? I don't see anything wrong with the plot!
Offline OchkovVF
#9 Posted : 13 March 2024 07:19:04(UTC)
OchkovVF
Offline StvMath
#10 Posted : 13 March 2024 07:27:07(UTC)
StvMath
United Kingdom
See please
Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle.
on 13/03/2024(UTC)
Offline OchkovVF
#11 Posted : 13 March 2024 07:30:06(UTC)
OchkovVF
See please
it's one bug?
Offline OchkovVF
#12 Posted : 13 March 2024 07:43:29(UTC)
OchkovVF
About this task see please pp 23-34 here
Study-8-Kinematic.pdf (2,212kb) downloaded 2 time(s). Study-8-Kinematic.pdf (2,212kb) downloaded 2 time(s).
The chapter 8 from the book
2^5 Problems for STEM Education
Now I am writing same chapter for the SMath book.
For me will be interesting your remarks.
Edited by user 13 March 2024 07:45:28(UTC)  | Reason: Not specified
Offline OchkovVF
#13 Posted : 13 March 2024 09:06:27(UTC)
OchkovVF
See the animation here
tchebyshev plantigrade
Offline uni
#14 Posted : 13 March 2024 19:21:14(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Я суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot?
Russia ☭ forever
Viacheslav N. Mezentsev
on 13/03/2024(UTC)
Offline OchkovVF
#15 Posted : 13 March 2024 19:34:28(UTC)
OchkovVF
Спасибо, Вячеслав, что откликнулся.
Суслик вот в чем.
На этом графике в его аргументе записана система с перечислением кривых.
Chebyshevs-Foot-Stepping-Machine-Trace.sm (178kb) downloaded 1 time(s).
Все ОК.
Затем для компактности документа я захотел использовать переменную Plot.
Формат графика сбился.
См. картинку наверху и
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (179kb) downloaded 0 time(s).
Offline uni
#16 Posted : 13 March 2024 19:57:59(UTC)
uni
Я попробовал и мне трудно было повторить условия возникновения такого поведения.
Настройки не должны слетать, если количество графиков между пересчётами документа не меняется. Если возникла ошибка во время построения одного из графиков, то настройки сохраняются. Если вы изменили количество отображаемых графиков (а оно определяется только во время пересчёта), то остальные графики "забываются".
Рекомендация: отключить автоматический пересчёт на время подобных манипуляций.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение.
Russia ☭ forever
on 13/03/2024(UTC)
Offline OchkovVF
#17 Posted : 13 March 2024 20:26:57(UTC)
OchkovVF
Спасибо!
Заодно подумайте и о:
1. После ввода выражения кривой видно весь график. А то приходится долго крутить мышкой.
2. Возможность фиксирования разброса графика так, чтобы его мышкой нельзя было менять.
Offline grelkin2
#18 Posted : 15 March 2024 18:23:36(UTC)
grelkin2
Я написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева.
http://razdvizh.site/chebl
Offline OchkovVF
#19 Posted : 15 March 2024 20:14:16(UTC)
OchkovVF
Спасибо за ценную информацию, но ссылка не работает
Offline OchkovVF
#20 Posted : 17 March 2024 00:18:38(UTC)
OchkovVF
I have change the roots function on the Newton function.
Now we can change variables r, L,01, L.02 etc and no problem!
16-4-Chebyshevs-Foot-Stepping-Machine-Trace-Newton.sm (931kb) downloaded 4 time(s).
2 Pages12>
